series parallel
ws9876
Solar Expert Posts: 453 ✭✭✭
Can you series 2 panels for 66 volts to a combiner and then 2 more parallel for 33 volts and put them in same combiner box??
No, the voltages must be within 10 percent of each other. The closer the better, less power loss.
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Assuming they are all the same panel, or compatible, you should run them in 2 sets of [2 in series].
I wouldnt do this but.....for theory it could be done and it would just average out voltage ,about 50 volts and amperage would add up with a certain loss..but it could be done yes??
I don't think it will work as a simple average. I presume you are using an MPPT controller which may get confused looking for the maximum power point. Also, I'm not sure how high a voltage (66 volts) you can backfeed a 33 volt panel with.
Apparently you have four 33 volt panels... why don't you just make two 66 volt strings?
- 231 Forum & Website
