How much wattage do I need to run my ham radio
martinhoover
martinhoover Registered Users Posts: 2
Hello, I am new to the solar world and I need some help on my first project. I am my ham radio operator and a backpacker and am trying to design a radio package for backpacking keeping it as light as possible. My question is how much wattage of by rollup type solar panel do I need to run my radio and keep the 13.2 V battery charged.
The specifications of my radio are on receive my radio uses one amp on transmit it uses 22 A at 100 W. Not transmit to receive time is less than 20%.
When I transmit or in a conversation it rarely goes over one minute in length. So that using 22 A and 100 W for a minute. My little 13.2 lithium battery that I have will last me on 100 W for about 30 minutes of normal talk time. My goal is to have a solar panel with enough wattage and voltage to keep my little battery charged.
Any help would be greatly appreciated as well as mathematical equations on how to figure this stuff out.
    You are a Ham Operator and cannot figure out watt hours consumed ?    Something is very fishy here......
    But to answer your question, 22A @ 13V is 286 watts consumed.   That is a full size Grid tie panel.  You might get away with a 100w of pv panel and limit your talk time even more.
  • Blindowl1234
    Blindowl1234 Registered Users Posts: 54 ✭✭
    When I read this I hope he meant 2.2 Amps not 22 amps. Something didn't sound right maybe I'm wrong lol
  • martinhoover
    Yes I am a ham operator. I'm new to the hobby. I have Run portable operations all across the southwest, southeast, northeast and Midwest.
    Nothing fishy here. I have over 440 portable contacts. I'm looking to keep my batteries charged with solar power. I am just trying to figure everything out. When I am using 100 W of transmit power out I am consuming 22 amp hours. My receive time is only one amp hour.
    I'm just attempting to configure all this and don't need any slack jawed comments. I'm now to solar and my long term goal is running my camp on solar power. Like I said my first project is to make sure I can have emergency communications.
  • vtmaps
    I am a bit concerned about terminology.  You have already confused Blindowl, and I'm not too sure about your loads.
    "Watts" is a rate of energy use.  WattHours is an amount of energy.  Thus 150 watts for 3 hours is 450 watthours of energy.
    Amps is a rate that charge (electrons) are moving.  AmpHours an amount of charge.
    A battery with an amphour rating holds a certain amount of charge... but you need to multiply that by the voltage in order to get the amount of energy that the battery stores.
    This quote, for example, makes no sense to me.  Are you trying to say that when your transmitter is using 100 watts, the battery is supplying 22 amps at about 13.2 volts?  If so, your battery is providing 290.4 watts.  Where's the other 190.4 watts?
    Or, are you trying to say that using 100 watts for a period of time draws 22 amphours from your battery?  If so, the period of time is:  100 watts ÷ 13.2 volts = 7.58 amps.   22 amphours ÷ 7.58 amps = 2.9 hours.
    In order to answer your question about what size solar array you need, I need to know your loads.  Because of terminology issues, I can't figure out from your posts how much energy you consume in a day.
  • Vic
    Hi martin ..,
    Welcome to the Forum.
    Martin probably has a Ham Transciever which uses a 12 V battery,  and is able to produce about 100 Watts of RF power output,  into an antenna.   In doing so,  it consumes the relatively customary amount of DC current from the 12 V source  --  22 - 23 ADC.
    I DO wonder,  if you have considered running somewhat less power ...   although the current required to produce 50 W RF  is often about 75% of that needed to produce 100 W of RF.
    Your transmissions seem quite short.   Are you a VHF Backpacker?
    Most roll-up PVs are not very efficient,  although,  guess that you have little choice for a packed setup.
    Why not consider a QRP radio that might be able to run about 10 - 15 watts output,  and try to make your antennas a bit better?
    FWIW,  73,  GL,    Vic
  • zoneblue
    The specifications of my radio are on receive my radio uses one amp on transmit it uses 22 A at 100 W. Not transmit to receive time is less than 20%. When I transmit or in a conversation it rarely goes over one minute in length. So that using 22 A and 100 W for a minute. My little 13.2 lithium battery that I have will last me on 100 W for about 30 minutes of normal talk time.
    Example anaylsys for one day, tweak as you need to:
    Radio RX :  12.8V * 1A =  12.8W for 0.5 hours is 6.4Wh/day
    Radion TX: 12.2V * 22A = 268W for 0.1 hours is 26.8Wh/day
    Total for the day is 39.6Wh
    To recharge that (assuming a sunny day), you are going to need a variation on these:
    -10Wp PV:  40Wh/10W/0.77/0.8 = 6.5 sun hours (small panel strapped to backpack)
    -30Wp PV:  40Wh/30W/0.77/0.8 = 2.2 sun hours (med sized panel at camp)
    -80Wp PV: 40Wh/80W/0.77/0.8 = 0.8 sun hours (go for broke)
    Sun hours here are equiv full sun hours, ie a hour at midday, longer teh further you go from midday. Cloudy/rainy, multiply everything by 5.  The two deratings are for your information, 0.77 for losses from  teh panel and controller, and 0.8 for the battery cycle efficiency.
  • zoneblue
    BTW, the smallest portable PV at the moment are the foldable units using sunpower back contact monoC cells. Theres a lot of rubbish out, do your homework.
    Dave Angelini Solar Expert Posts: 7,075 ✭✭✭✭✭✭
    Well, my wife has been an extra class since the mid-nineties. She memorized the answers and learned 20 words per minute of code
    for about 3 weeks. All she knew about watts was that there better be enough to run the hairdryer on our sailboat in the tropics.
  • cow_rancher
    cow_rancher Solar Expert Posts: 117 ✭✭✭✭
    Well she has the important stuff down, hey good buddy what's it look like in your neck of the woods.
    What more is there.
    General Class, or as my XYL tells me, No Class...
    Rancher
    It looks like the humidity is rising out the window in the Merced river basin!   Where are you Ranching?
  • cow_rancher
    SE AZ
    Since the OP is not back yet....  South East Arizona came very very close to where we built our home. I go back there as much as I can.
    The birds, friends/clients and desertcsape are just a few of the reasons.  Nice!
