anyone seen the orson power thing
t00ls
Solar Expert Posts: 282 ✭✭✭✭
heres there website
https://www.kickstarter.com/projects/ericclifton/orison-rethink-the-power-of-energy?ref=launchboom-si-h-d&utm_source=launchboom&utm_medium=ads&utm_campaign=launchboom-si-h-d
they are telling people this is JUST plug and play.....no need for an installer.....they also dont tell you to inform the power company that you are backfeeding the grid
so much snake oil in this thing
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
Note that they are not backfeeding the grid. They do not supply more power than your loads are taking.t00ls said:
Would thy not backfeed the grid during a power outage if there were no loads at the time?
Don't think so. Existing hybrid inverters don't do that, and they state specifically that they do not backfeed.westbranch said:Would thy not backfeed the grid during a power outage if there were no loads at the time?
From talking to a co-worker who looked at one of these, this is basically a hybrid inverter (with the usual anti-islanding protections) with a small battery.
I guess what threw me is their statement that it's PLUG and PLAY and all the previous units discussed here have been p&p into the house wiring via a wall socket... that and the picture of that avant guard lamp like talking feature i the living room...
thing is...it is connected to the grid while supplying power to the home...on only one side of 2 legs of 120v.......NEC does not allow this
power companies do not allow you to just plug something in that produces power while connected to the grid, without first informing them
PV installers have to go through all kinds of inspections just to connect a grid tie device.....these guys think they can go around that
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
A device plugged into a wall socket has no way of knowing the difference between a load somewhere in the house and the load provided by the grid. If it is backfeeding the local loads it is also backfeeding the grid should the local loads consume less than the inverter is putting out.bill von novak said:
Technically, any load with inductance or capacitance "backfeeds the grid".
- 231 Forum & Website
