honda eu20i oil light
petertearai
Solar Expert Posts: 471 ✭✭✭✭
Just got a new honda gen . sales man in shop said when oil is low the oil light will come on .but the generator will not automatically stop on low oil .
But reading the manual it says there IS a low oil shut down . can a assume the suplyers sales man is incorrect .?
2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
It will shut down when the oil is low, It has a sensor. I really haven't had a issue with mine, but sometimes if it won't start check the oil, I'v had to add oil before starting. I have read that when the oil is dirty it can be a problem also, gets bubbles on it. It does have a oil alert light , but I don't know what turns it on, if the generator isn't running it has no power, maybe it's a two step process.
If you buy one of those spouts on ebay you can change the oil in 2 minutes. I have a detergent bottle I cut off with a mark ( just shy of 16 oz. ) I fill it with fresh oil. Remove dip stick, install spout, Tip it over to drain to drain into a waste oil container and tip it back to fill and remove spout and reinstall the dip stick. done.
https://groups.yahoo.com/neo/groups/Honda_EU2000_Generators/info
It shuts down on low oil. As Blackcherry mentioned, when oil is dirty the oil sensor sticks. The generator will start, but shut down in less than a minute. As it warms up some, the generator will run fine. Sometimes it takes 3 starts before it will keep going. In cold weather, the oil can be dirty enough in just 30 hours runtime to cause this problem.
btw, my eu2000 has many, unknown thousands of hours on it... it don't owe me a nickel. I will buy another when the time comes.
Make sure the unit is as close to level as you can get... I had mine shut down for 'low oil',... checked and it was fine, then noticed that it was sitting at a bit of an angle off level, re-positioned it and voila, no problem...
Thanks for all replys . what s fantastic forum .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
It doesn't take much to stop the generator. I have the EU1000 and a couple of tablespoons of oil can make the difference between running and not.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
