Comparison between 3 different L16 type batteries.
2
  • Vic
    Hi IB,
    Have not been to the Link,  as assume that it is a commercial.
    The type of battery type selected for an application is very specific to that application.   AGM and Flooded batteries,  often,  are not simple equivalents,  differentiated only by price.
    For the general off-grid battery user,  AGM batteries can be difficult to manage,  especially in parallel strings.   They almost always have less cycle-life at a given DOD,  and so on.
    For some applications,  AGM is a clear winner,  if they are carefully managed (just as are FLAs for some other applications).
    Just another opinion,   Vic
  • zoneblue
    Resurrecting a 2 year old thread to promote your website as a first post?
    Lets see if he will address some of your questions... Not a lot of technical in the Blog link.
  • Mangas
    Has anyone had longer term experience with those specific AGM batteries, specifically to reliability and durability?
    I realize that AGM technology has improved but with our sizeable battery bank investment the L16 flooded variety has been very reliable (and forgiving) over the years despite maintenance.
    Dave Angelini Solar Expert Posts: 7,075 ✭✭✭✭✭✭
    I watch over a few AGM systems. Mainly because one guy is merchant marine and another is in a really small space.  They last about 5 years and then lose capacity and have bad cells. I can get flooded L16's at about $300 in either 6V 400AH or the 2V  1,100AH and so it seems silly to me get something I can't measure SG on and get 10 years or more of life. I wish I did not have to spend the 15 minutes a month doing maintenance but I know I would spend more time with an AGM making sure the voltage was perfect.
  • Mangas
    Good analysis Dave.
    I'm just not confident enough yet to switch to AGMs.
    Maintenance on 64 L16s' really is not a big deal.  About 1 1/2 hours, three or four times a year.
    Next set, try the 1,100 AH's. Only 24 cells to look at! Obviously don't use the Trojan 1,100's . Good batteries but bonehead design with 3 cells per 2V battery.
    Has the lifetime of AGM increased at all yet ?
    5 years is what I hear and experience if perfectly managed at max DCV. The cost for an L16 400 ah AGM is better but unless you are gone for months, have really small power room, or can't follow basic directions you should use flooded. Money to burn should be on the list as there are those who feel it is worth it.
  • zoneblue
    edited November 2015 #41
    If youre going anywhere from FLA for the reasons mentioned, it would be LFP. The numbers on the lithiums are now pretty good. Higher up front cost should pan out with lifetime performance.
    edited November 2015 #42
    The LFP  L16 is available for normal offgrid people like you and me in New Zealand?  It sure is not here in the positive latitudes.
  • LyleT
    LyleT Registered Users Posts: 1
    Hi. Just looking for some help here. I have 8 x 6v 370ah batteries for our off-grid solar system. I purchased a BMV 700 battery monitor and I need to provide a ah figure. Would it be per battery or a combined ah (370x6=2220ah)? Thanks
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    edited January 2017 #44
    Depends on the voltage of your system.
     48 volt= 1series string =370 ah
     24 volt = 2 series strings = 740 ah
    12 volt, 4 series strings (if so you should have 2 volt batteries) = 1480 ah
    Are you still out on Catalina Littleharbor2 ?   Must be wild out in the anchorage! Hope you are in Baja....
  • littleharbor2
    Getting dumped on here on the Island. The seas are actually very calm, just lots of rain.  Sure wish I was in Baja. We were supposed to go after Christmas and next week but have had to cancel both trips Shooting for February.
  • softdown
    softdown Solar Expert Posts: 4,034 ✭✭✭✭
    Rayovac solar batteries? Never heard of them. Likely made by one of the majors.
  • Saggys
    Saggys Solar Expert Posts: 189 ✭✭✭
    I have been using 2-Rayovac L-16's for the last year and a half with good results. They were available locally and cheap so I thought I would try them, so far so good.
  • softdown
    Catalina Island or the Baja peninsula? Life is tough!
  • littleharbor2
    edited March 2017 #50
    Someone's gotta do it. I'm happy to be that guy. Heading back south for a month in a few weeks. Personally I'll take Baja over Catalina any time. Been living on this tourist trap for 45 years now and am not happy with the new Wrigley regime. They are turning this Island into a "high end resort" and the way things are going it is going to be cheaper to vacation in Hawaii than here.
    We have paid as much as $7.69 a gallon for gas, Guess who runs the only gas station?
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    I used spend good portions of my summers down in Avalon in the late 60's. Captain Cooper with the Catalina Island Co. was the "go to" guy to get inland travel passes and gate keys. We helped him out now and then, so he was lenient with us so we got explore the roads on two wheels. We surfed Shark Harbor when the break was good.
  • littleharbor2
    Ahh. You were one of Captain Coopers Troopers. We in the IMC, Islanders Motorcycle Club, had a song about him but to type out the lyrics here I would have to Bleep out half the words.
     Spent my adolescent, and, actually all most my years here surfing, camping, hiking, fishing, 4 wheeling, riding motocross and waterskiing. We were too busy to get into trouble, most of the time.
  • Marc Kurth
    edited March 2017 #53
    I know the song well :smiley: (It ends with semi rhyming vulgarities  "XXXX, XXXX, XXXX, XXXX , we're the IMC!!)
    Nah, our "trouble" was just mischievous stuff. What year did you arrive there? As I recall, the Class of '68 had 9 students graduate.
    I rarely got up to the isthmus because the mainland girls came in on Big White and the round bottomed Water Taxi's.
    I miss catching Sanddabs about 1/2 mile off the old quarry (using squid for bait) - pan fry in butter and touch of garlic!
  • littleharbor2
    Ha ha, that's funny you know the song.
    I got here in 1972, graduated in 76',  lived here ever since.
    Ya, Horny corner (the foot of the pier) holds many fond memories for a lot of us.
    We have gotten partial to White Seabass, Halibut and Bonito shark. Not to mention Lobster and Abalone. Not bad fare when you are camping on the backside of the Island.
  • softdown
    '76 Graduates Represent!
  • littleharbor2
    Yep, Class of 76' RULES.
  • Marc Kurth
    edited March 2017 #57
    Since we have already derailed this 2012 thread:
    You are causing a lot of good memories to surface! We likely overlapped in Avalon because my last trip would have been between '74 and '75. My checkout/certification dive was off of Frog Rock about then.
    Here are some memories that I'll bet you know:
    - The Wild Goose on her own can when she came in. His grand daughters and friends partying on board until dawn.
    - Dick Reineman on his mahogany/teak classic racing cutter "Branta" (He loved to show his considerable skills when the channel was standing up)
    - A local teenage guy named Dana, who's father was the only plumber in Avalon.He rode a classic Yamaha Enduro and was always in the action with the tourist girls.
    - Jack (?) the Harbor Master working hard to help when people who didn't understand what happens when the Santa Ana's came.
    - The swim race competition for the two summer lifeguard jobs - on the worlds smallest beaches flanking the pier......
    Man, that was a long time ago....
  • littleharbor2
    edited March 2017 #58
    No kidding , completely derailed, oops.
     Wild Goose, synonymous with the one and only John Wayne. Unlike todays celebrities he would come into town and mingle with the public. Very nice man.
     Dick Reineman  doesn't ring a bell.
     Dana Porter, I went to school with him. Sadly committed suicide in the late 70's, or possibly early 80's.
    The "Northeasterns" were Santa Ana winds which could go from 0 to 60, literally in an hour. Caught lots of yachters off guard, especially sailboats which didn't have the power to get out of the harbor and around the backside of the Island. I surfed many a wave in the normally placid waters of Avalon Bay.
     The lifeguards had a pretty easy job in the summer. There aren't lifeguards on the beaches any more but now that they're Lifeguard/Paramedics they are pretty busy dealing with diving and boating accidents of which there are plenty of especially since this place has reached saturation plus level of popularity. Year round tourism these days. Summer is absolutely nuts.
     Marc, I enjoy reminiscing the good old days, Thanks for your questions.
    edited March 2017 #59
    Ever see Bogie on "Santana" She was all over the place based out of SF.
    https://www.youtube.com/watch?v=QimAPSpaDec
    We spent a few months there in 93 on Astraea. Easier fishing south :)
  • softdown
    Not derailed.....revived after a six year hibernation. You guys are making me homesick for Catalina and I've never even been there.
  • littleharbor2
    Can't say that I have, Dave. San Felipe doesn't seem like a big sailing destination with all the shallow water and extreme tides. Don't see many sailboats anyway. I'll agree the LEGAL fishing is better down south.
    Totoaba have been protected and poached for decades but now the Chineese are paying thousands of dollars each for dried Totoaba swim bladders. The poaching continues with authorities being paid off and the last 30 or so Vaquita dolphin will soon be gone forever. Extinct.
