Cable for linking two 6 volt batteries
Tom Cleary
Solar Expert Posts: 37 ✭
Hello,
I would like to link in series two 6 volt Amstron AGM deep cycle batteries (model APGC2) that I am purchasing from Atbatt. I wonder what gauge battery cables will work for this purpose?
The cables will also require battery eyelets wide enough to fit over the secondary posts of the Amstron, and I wonder if it is better to find a vendor for them or plan on making my own? Any suggestions would be extremely welcome (:
Tom
What is the maximum current you plan on pulling/charging with the battery string?
Making good quality cables usually requires a hydraulic crimping tool and finding the right terminal ends. If this is a one off job--If you have a local/helpful battery shop (or welding supply company), let them make the cables for you.
If you are a DIY type person, there are manual "hammer" crimpers and sometimes you can find a good deal on hydraulic.
One poster here bought a cheap bold cutter--Used a torch to heat the cutting blades to remove the temper. Drilled holes in the blades to crimp. Then reheated the blades and quenched them (old or water?) to re-temper. Was very happy with the results.
I used this company's on my latest build: http://www.pv-cables.com/Products-Battery_Cables.html They do all the regular custom sizes and options, in 3/8 or 5/16 rings. Seem to have good workmanship and reasonable prices.6 250W Renogy panels / Morningstar TriStar MPPT 60 charge controller / 8 Costco CG-2 batteries @ 24V / Samlex PST-1000-24 inverter / Samlex SDC-23 24/12V converter and BG-60 LVD / Midnite Solar boxes, breakers, etc.
It isn't hard to make cables. It isn't worth getting the equipment unless one needs quite a few.
Our host offers a variety of cables: http://www.solar-electric.com/catalogsearch/result/?q=battery+cables&cat=0
Or do what i did before i got a crimper, take it to your local auto electrician armed with a few beers,
- 621 Discussion Forums/Café
