How would you use this type of 24v generator?
I found this exact generator for under $200.00. New, with regulator; generator outputs 500+ amps....
Not sure how to use it as a backup genny for a 5kw "off grid" battery backup Outback system. Eight batteries are L-16 440ah, 6v., but could go to a new forklift battery that's a little larger in rating..
How would you use it and spin it?
Ushttp://www.ebay.com/itm/170729289827?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX
Thanks,
Bill
I have no idea what you would use to power it on a long term basis or even whether it has a pulley on it already of just a keyed shaft.
If you have a tractor with a PTO that would be a good way to power it for emergency use.
The 28V output, if not adjustable, is not going to be great for battery charging on a 24V bank.
It seems more suited to directly driving a large set of 28V loads.
SMA SB 3000, old BP panels. -
28V would be ideal to charge a 24V bank...
I'd be fine with the 28v output, for emergency use you would be fine, it's much more capable generator than you need since a 880 ah (100 hr rate? so really @ 780?) so more than about 13% would be more than you need.
Do you weld? Might check out Zena or Underhood truck welders, I think they both make 24 volt versions that can be mounted to a motor and has regulated charging....
Photowhit,
Here's the data on the batteries I have. It should be 420ah, not 440ah. Together they are rated at 840ah @ 20hrs, with two 24v strings and then in parallel for a 24 system. From what I've gathered, these batteries will last about 3 years before failing, so their not the super ones on the market..... One fellow I know had Trojan, then went to these, but went back to Trojans after experiencing the U.S. Battery's 3 yr. lifespan.
http://usbattery.com/products/6-volt-batteries/us-l16hc-xc2/
This generator/alternator comes with it's own regulator attached. I just wish I knew how something this powerful could be used to its 570 amp ability toward home power and backup.... I do weld, but don't need this for a portable power source welding system.
Thanks,
Bill
Bill -
This generator would need about a 30 hp fuel powered motor/engine for full load.
Bill,
L16 flooded (floor scrubber) batteries should last at least 5 years if not abused, I use to use 5-7 years as an expected life for those.
The reason I mentioned the Underhood welding units, is they are designed to mount under the hood of trucks either replacing the alternator or in addition to the alternator. I helped a friend purchase an Underhood version, I think for around $450 a few years back for his ford F250 and one of the options was a 24 volt unit. Looks like prices have really gone up on these now. Just thought it might be a reasonable emergency backup and added functionality.
Any battery will have a short 3 year lifespan if not taken care of. The US RE L16 series have been very reliable. Both the 400 & 1,100 AH cells. 4 clients using them over 4 years. I expect them to go for 10 years."we go where power lines don't" Sierra Nevada mountain area
Here is an update on information of this generator. It's the PDF data sheet showing RPM and wattage output. It appears this generator/alternator can generate ample charging power without going to its full RPM or to its high amp rating (i.e. 1500 rpm)How would you use something like this?
Bill -
I am not sure exactly what you are asking...
I have found some wiring and installation instructions on the web (seems to take a standard belt drive). And it needs an external regulator. It appears it would take ~10 kWatt of drive power (~13 to 18 Horse Power) to drive rated current at 2,000 RPM...
Electrical wiring information:
http://www.ceniehoff.com/Documents/Ctrl_Hyperlink/TG56B_uid6920111006491.pdf
Thanks,
Bill
BB. said:I am not sure exactly what you are asking...
One other question I have is about email notices when someone posts to my thread. How do I get it set to send notices to my email?
Thanks for the time and help!
Bill
Bill -
I have a John Deere X-500 with a 22hp twin cylinder engine. It just sits after the first frost and stays until the March warmth shows up. Making a quick release bracket mount for a direct belt drive to it wouldn't be too much of a problem.
Thanks again for the link,
Bill
Bill
- 226 Forum & Website
- 617 Discussion Forums/Café
