Question for those in the know!
Lobo
Registered Users Posts: 18 ✭
I have a dehumidifier that I need to run 24 hours a day constantly. It is a 115V unit with a rated 6.9amp draw and 750 watts. What would be needed for operation of this unit while using 12 volt panels. Second, battery recommendations? Thank you in advance for any help.
750 watts X 24 hours = 18 kilowatthours per day energy consumption.
Typically we recommend that your daily load should equal 1/4 of a battery's capacity. Thus you would want a 72 kwh battery. A 12 volt battery bank with 72 kwh capacity is a 6000 amphour battery bank.
To charge it with solar you would need about 8 large charge controllers, with each controller having about 1250 watts of solar panels.
To build a 6000 amphour battery bank at 12 volts will require multiple parallel batteries, which is a poor design... you would be better off with a single string of 1500 amphour batteries configured at 48 volts. With a 48 volt battery you would only need 2 large charge controllers, each with 5000 watts of solar panels.
Thank you!
Basically, you need a different way to humidify the air. Humidifiers have a heating element which uses a good bit of electric.
Perhaps a mister... or evaporative cooler, these use a fan and membrane or just a fan and a fine mist. a 8-40 watt fan is the major energy use...
I think he's trying to remove humidity.
Hi what type of dehumidifier do you have . That seems to use a lot of energy.2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
You would use a mini-split heat pump to dehumidify !"we go where power lines don't" Sierra Nevada mountain area
