One 'large bank or two 'small banks
freecr
Registered Users Posts: 1
Hi all, brand spanking new to the site. I want to set up a solar system for an RV. My question should be simple enough in essence. Am I better off to use one battery bank while the 2nd one charges, and then after a while (when at say 50% or whatever) switch it the other way, or is it better to combine the two halves into one larger bank and use and charge at the same time. Is there pros and cons for either. I can easily set up a controller to make before break to switch 'em back and forth. I would think giving batteries a little time off might extend their life plus if ever something bad happens only half the system suffers, but this seems uncommon so there's probably a reason.
Also to make it more difficult, one reason to ask is because I have some 75AH optimas that are 2 months old, and if I add more storage I'd like to buy and use some 125AH. Both battery types would be AGM. I know the difference isn't enough to prevent linking them. It's not optimal but should be OK.
thanks
freecr
thanks
freecr
I seem to remember a similar thread over in the RV section about having 2 sets of batteries and one 21V and the other 24V, and ended up with one set ..have a look...
hth
KISS one bank
One bank, but a separator starter battery!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
That's what I was thinking, one bank is enough to worry about. Why double the things that could bother?
- 228 Forum & Website
- 618 Discussion Forums/Café
