"Number of Posts" Indicator
crewzer
Registered Users, Solar Expert Posts: 1,832 ✭✭✭✭
We seem to have lost track of our numbers of posts.
For example, my number dropped by >55%. At one level, I suppose it doesn't matter, but, at another level, an accurate indicator reveals a measure of commitment by the "senior" forum members.
What happended?
Thanks,
Jim / crewzer
What happended?
Thanks,
Jim / crewzer
Re: "Number of Posts" Indicator
It's also an indicator of the stability of the message board software.
Gee, when I search for "new" posts, am I really seeing all of them ? Sometimes edits work, sometimes not. Maybe the new software has lots of flashy blinky lights somewhere, but if it compromises the boards function, how do we know?
Do we compare the existing messages to our local message database (whoops, I DON'T have a local database, but I thought I remembered I posted something about XYZ last month)
This is a most comprehensive board, and yet I'm slowly losing faith in it's accuracy, seeing all the buggy reports this last month. Is there a software patch that has not been applied, or the host machine running out of RAM/disk space?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Have we lost all posts more than a year old?
Thanks,
Jim / crewzer -
I don't think ALL Crewzer. My original posts on the chest freezer from almost 2 years ago are still there. My user id was invalid, but the posts remained.
HTH,
Jay -
OK... thx. Maybe I'm just having trouble figuring out how/if the search engine on this new forum works...
Regards,
Jim / crewzer -
when you had first brought up about your number of posts being reduced jim my numbers for posts were fine, but now my numbers are 1/3 of what they were as i was close to 2500 posts before and now about 820. maybe the software is accurately counting the number of posts, but maybe some of those posts are eliminated now. i'm guessing they weren't eliminated by the number of posts i see in each general catagory. -
A while back, when I first moved to the new board, I had it purge all messages over 2 years old, I guess it finally got around to recounting them.
I also went through and deleted some old obsolete messages that no longer pertained to anything that is now relevant, like posts referring to the old board. -
Understood. I was searching for some old posts to use as references, but they apear to be gone. I'll start keeping a better "local" library.
It's still a great forum!
Thx,
Jim / crewzer -
i had hundreds, i actually LOST my account in the upgrade, had to start over and am now classified as a "new guy". re old posts: as you know i often share pearls of wisdom for you all, and now those old posts are gone.. seriously, theres SO much info it would be nice if you could keep the older stuff. for example: after a while you see the same questions over and over, its nice that people can search. another example is i wanted to see what my old stove power measurements were as they compared to a new unit: those posts are gone. anyhow, yes, i vote for more longevity of posts.
better yet may be an archived section. -
Just wanted to remove the "0" posts..... Originally, I was just visiting. I decided to register after reviewing the fine quality of the discussions. -
Re: "Number of Posts" Indicatorthose posts are gone. anyhow, yes, i vote for more longevity of posts.
The old software had gone through about 5-6 updates, and when I moved to this new program, some of the messages from mid 2006 and earlier had apparently gotten corrupted. They were there, but all the header info such as who from, subject, etc was all gone so I had to prune them out.
Right now I have the board set to remove any messages over 900 days with no replies. -
Re: "Number of Posts" IndicatorThe old software had gone through about 5-6 updates, and when I moved to this new program, some of the messages from mid 2006 and earlier had apparently gotten corrupted. They were there, but all the header info such as who from, subject, etc was all gone so I had to prune them out.
Right now I have the board set to remove any messages over 900 days with no replies.Perhaps, you could randomly recycle them in a "Old Post" of the day thread.... sans any of the attributions.....might help regenerate interesting discussions and avoid constant FAQ's
- 228 Forum & Website
- 618 Discussion Forums/Café
