Combiner box wiring size
just starting
just starting Registered Users Posts: 235 ✭✭✭
Is 12 awg ok to use in my combiner box it's 8" piece of wire on + and- I have two strings of three 250 watt panels that will be about 80' from Scc I plan to use 8 awg from Home Depot for the run I will rewire the combiner box if I have to
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024  - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher  Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
    250 watt panels, so I'm guessing about 8-9 amps, 12 gauge should carry that and more without a problem... If it is for the combined strings16 amps would be a bit closer, but over a short distance I would be fine with it, but if you have 8 gauge around and it's simple why not replace it...
  • just starting
    I don't know if 8awg will fit mc4 connectors
  • just starting
    Combiner box uses mc4 in and out guess I could take them out and hard wire to fuse holder and Scc
    Sorry, You will be fine with 12 gauge, I was using power distribution numbers which put 12 ga a bit small, but for a short run you will have no problem. They want to limit the current in long runs for several reasons, voltage drop, heat build up in confined places like conduit....
