Honda EU2000i conversion to DC generator?
90cummins
Solar Expert Posts: 57 ✭✭
I acquired and rebuilt a Honda EU2000i that had a bad engine and have been thinking about ways to support my 24v battery bank directly with DC power.
Being 120v output only I cannot use it to support my inverter.
It operates by generating 200+- volts ac and rectify's it to DC which the internal inverter converts to 120v ac power.
My question; has anyone thought of bypassing the internal inverter to have a 24 or 48v output that can directly charge batteries.
90cummins
90cummins
Re: Honda EU2000i conversion to DC generator?
As you know, you could use a transformer to step-up the 120 VAC output of the Honda genset to 240 VAC for the XW inverter.
OR, you could find a transformer that has 50 - 60 V AC output, add a full-wave rectifier, filter capacitors, and run this DC into a Charge Controller which could charge your batteries. OR, perhaps add a Variable Autotransformer on the input side of the transformer, and then you will be the CC, by watching the charge voltage and current.
But, to me, trying to adapt the Honda's three-phase alternator to battery charging is a bit of an engineering project, that might have disappointing results along the way.
YMMV, Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
If the genset is working well... Just get a good AC charger or inverter-charger. The conversion losses are probably not that high vs the usefulness of 120 VAC power and auto/eco throttle.
Because is it three phase--You would need three transformers and 6 (minimum) diode rectifiers (plus heat sinks, etc.). Unless you have some very special application, it would seem not to be very practical or cost effective.
NO. it won't work well as a DC charger.
The generator windings are fine wires for high voltage. If you reduce the voltage, you are still limited by the current the windings will work at without burning up.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I would ebay a slightly used 24 volt charger. Keep it simple.
Then if one or the other quits working you can figure it out which is the offending item real easy.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
Shop around, there are better deals to be found.Delete generator website spammer. -Bill -
In years past, I have used these folks for a couple Honda's:
www.wisesales.com
www.mayberrys.com
Just a couple other places to research.
