Honda EU2000i conversion to DC generator?
90cummins
90cummins Solar Expert Posts: 57 ✭✭
I acquired and rebuilt a Honda EU2000i that had a bad engine and have been thinking about ways to support my 24v battery bank directly with DC power.
Being 120v output only I cannot use it to support my inverter.
It operates by generating 200+- volts ac and rectify's it to DC which the internal inverter converts to 120v ac power.
My question; has anyone thought of bypassing the internal inverter to have a 24 or 48v output that can directly charge batteries.
90cummins
  • Vic
    Re: Honda EU2000i conversion to DC generator?
    As you know, you could use a transformer to step-up the 120 VAC output of the Honda genset to 240 VAC for the XW inverter.
    OR, you could find a transformer that has 50 - 60 V AC output, add a full-wave rectifier, filter capacitors, and run this DC into a Charge Controller which could charge your batteries. OR, perhaps add a Variable Autotransformer on the input side of the transformer, and then you will be the CC, by watching the charge voltage and current.
    But, to me, trying to adapt the Honda's three-phase alternator to battery charging is a bit of an engineering project, that might have disappointing results along the way.
    YMMV, Good Luck, Vic
    BB. Super Moderators, Administrators Posts: 33,683 admin
    If the genset is working well... Just get a good AC charger or inverter-charger. The conversion losses are probably not that high vs the usefulness of 120 VAC power and auto/eco throttle.
    Because is it three phase--You would need three transformers and 6 (minimum) diode rectifiers (plus heat sinks, etc.). Unless you have some very special application, it would seem not to be very practical or cost effective.
    NO. it won't work well as a DC charger.
    The generator windings are fine wires for high voltage. If you reduce the voltage, you are still limited by the current the windings will work at without burning up.
  • oil pan 4
    I would ebay a slightly used 24 volt charger. Keep it simple.
    Then if one or the other quits working you can figure it out which is the offending item real easy.
  • Blackcherry04
    Tiffany56 wrote: »
    Delete generator website spammer. -Bill
    Shop around, there are better deals to be found.
    In years past, I have used these folks for a couple Honda's:
    www.wisesales.com
    www.mayberrys.com
    Just a couple other places to research.
  • Mountain Don
    Electricgeneratordepot
