Generators with ful remote start capability
Les Nagy
Solar Expert Posts: 121 ✭✭
I am looking for a generator that has full remote start capability. The problem here n Chile is that they tend to sell cheap generators at high prices and with no up front sales support to find what is needed. The requirements are:
Minimum 2kW continuous rated output
Minimum 6 hr autonomy
Relative clean output
Gasoline, air cooled
220V 50hz
Full remote start without need to pull a choke or similar
What says the herd?
220V 50hz
What says the herd?
Re: Generators with ful remote start capability
Me too !
"The message you have entered is too short. Please lengthen your message to at least 15 characters"Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Honda Inverter style 3000W surge rated should do for what you have stated, quiet, economical to run and dependable
You'll have to find a Honda EU30is to get 230 / 50hz. You can then install a auto choke kit.
http://www.pinellaspowerproducts.com/view/HEUAUTOCHOKE/
You don't say what Inverter you have, but the AGS on some will start it or a Atkinson start module may have to be added. -
Thank you for the replies. -
Re: Generators with ful remote start capabilityThank you for the replies.
Or a Yamaha 6300IS (5000-6000watts) 50 hz 240 unit. It already has auto choke, remote start, etc.
Just don't even think of starting it up on eco with a medium load. For some reason it doesn't like that, at all.
I lost mine that way for some very weird reason that I will never know, I guess. Don't ask me please.
But otherwise, seems to be a solid unit.:-)Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
Find the international version of the Honda em4000sx? The "sx" is important... That has the full electronic engine control/computer -- So gives you auto choke.
http://www.mayberrys.com/Honda/generators/em4000.aspx
This may be similar?
Generadores de energía Honda EM-4500-SX
Make sure you get a clear understanding of what generator is being offered... The "SX" versions are not always easy to find (it appears) and the dealer many not even know/understand the differences until you explain.
- 234 Forum & Website
