Generators with ful remote start capability
Les Nagy
Les Nagy Solar Expert Posts: 121 ✭✭
I am looking for a generator that has full remote start capability. The problem here n Chile is that they tend to sell cheap generators at high prices and with no up front sales support to find what is needed. The requirements are:
Minimum 2kW continuous rated output
Minimum 6 hr autonomy
Relative clean output
Gasoline, air cooled
220V 50hz
Full remote start without need to pull a choke or similar
What says the herd?
    Re: Generators with ful remote start capability
    Me too !
    "The message you have entered is too short. Please lengthen your message to at least 15 characters"
    Honda Inverter style 3000W surge rated should do for what you have stated, quiet, economical to run and dependable
  • Blackcherry04
    You'll have to find a Honda EU30is to get 230 / 50hz. You can then install a auto choke kit.
    http://www.pinellaspowerproducts.com/view/HEUAUTOCHOKE/
    You don't say what Inverter you have, but the AGS on some will start it or a Atkinson start module may have to be added.
  • Les Nagy
    Thank you for the replies.
  • Surfpath
    Surfpath Solar Expert Posts: 468 ✭✭✭
    Les Nagy wrote: »
    Or a Yamaha 6300IS (5000-6000watts) 50 hz 240 unit. It already has auto choke, remote start, etc.
    Just don't even think of starting it up on eco with a medium load. For some reason it doesn't like that, at all. :cry:
    I lost mine that way for some very weird reason that I will never know, I guess. Don't ask me please.
    But otherwise, seems to be a solid unit.:-)
    Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid.
    BB. Super Moderators, Administrators Posts: 33,722 admin
    Find the international version of the Honda em4000sx? The "sx" is important... That has the full electronic engine control/computer -- So gives you auto choke.
    http://www.mayberrys.com/Honda/generators/em4000.aspx
    This may be similar?
    Generadores de energía Honda EM-4500-SX
    Make sure you get a clear understanding of what generator is being offered... The "SX" versions are not always easy to find (it appears) and the dealer many not even know/understand the differences until you explain.
