these things work? (Energy Controller Unit (KVAR PU1200))
andersondiaz
andersondiaz Registered Users Posts: 22 ✭✭
I do not know if it's a topic to discuss in this forum.
*but they say we can save on our electricity bill.
ask me, these things really work?
http://www.kvarnational.com/Patent_Certifications.html
http://www.kvarnational.com/NASA.html
    Re: these things work? (Energy Controller Unit (KVAR PU1200))
    They really work at correcting PF. And they don't change your bill one bit, because you are not billed for PF. It's a rip-off.
  • inetdog
    And any PF correction equipment which does is not switched in and out of the circuit along with the major low PF loads (A/C or heat pump compressor motors for example) will likely overcorrect when the equipment is not running and so cause a lower power factor at those times. End result is that it still does not change your bill, but it also does not decrease your very small I2R losses a much as their analysis indicates either.
    I have talked to a few honest electrical contractors who got distributorships and ended up dropping out and refunding the customers' money on their own to maintain good will.
    SMA SB 3000, old BP panels.
    BB. Super Moderators, Administrators Posts: 33,731 admin
    From 2010 discussion about same type of product:
    Power Save 1200 Capacitor
