water proofing electric lines for water pump
Photowhit
Solar Expert Posts: 6,023 ✭✭✭✭✭
Okay, I haven't even googled it yet...
...but I want to help a friends do a DC water pump in the bottom of a 35 gallon barrel, problem is the leads are only 18" long, I've used marine shrink tubing for boats, but no wiring that would be immersed in water. Does anything really work? It's a sealed pump so I have to extend the leads.
Thanks in advance!
Thanks in advance!
Re: water proofing electric lines for water pump
You need a 240V well pump splice kit. It's got 2 layer heat shrink for each power lead. You need an electric heat shrink gun to properly melt the inner layer, and then have the outer shrink layer seal it all up.
Less than $10 at a well stocked hardware store.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 234 Forum & Website
