Bus bar calculation steps
AJITNAYAK
Registered Users Posts: 11 ✭
Dear all.
I am new to designing bus bar calculation. can you suggest list of point tobe considered while designing of bus bar. Where i can get step by step procedure construction.
I have one bus bar in what way it get affected with temperature. how can we measure effect of temperature on bus bar.
Re: Bus bar calculation steps
Way too much work to calculate temperature effects on copper bus bar. Using common charts, you can find what size (cross section) is needed for your power usage. If worried, go one step larger and you should be fine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This guide and calculator may help out a lot:
http://www.bdbatteries.com/buss-bars.php
Measuring bus bar temperatures is conveniently done with a multimeter that has a temperature probe. Or, you can use an infrared pointing thermometer, which may be more convenient. If your bus bar is too hot, even though you have designed it correctly, it could be an indication of a weak / loose / corroded connection from the battery terminal to the bus bar itself.
- 230 Forum & Website
