Suppliers and feedback on 120VAC micro inverters for use with PV panels
cleantech
Registered Users Posts: 1
I am looking for a 120VAC micro inverter to mount to PV panels that will allow me to plug into a standard 120VAC outlet rather than grid tie it into the 240VAC breaker panel. My goal is to string together 2-4 PV panels (number of panels limited by the maximum current a 120VAC outlet can support).
I have found a few suppliers of 120VAC micro inverters and wanted to find out if anyone had any experience with them. Below are some of those I found after searching the Internet. Some have high shipping costs ($100-$150) since they are shipped from China to the US with 20+ day shipping times. In many cases the shipping cost is higher than the product cost.
HTAC Micro-Inverter 300-320 watt 12-60VDC Low Volt Input - $169
Caki Power IP65 - $137
DIY Solar WV-250 - $140
Re: Suppliers and feedback on 120VAC micro inverters for use with PV panels
Do not touch these with a 40 foot power pole. They are dangerous and illegal to install.
There have been numerous threads discussing these sort of "plug-n-play" inverters and why they are a bad idea. -
I don't think you will get anyone here to recommend doing what your trying to do. In the USA it is generally illegal to back-feed the grid without the utilities permission. You run the risk of overloading the circuit you pick to push to. And un-permitted installs are a big red flag for insurance companies and may prevent them from having liability and paying on a policy.
Better to back up 2 steps and do it correctly. -
I'll let others point out that there are a variety of reasons why this isn't a good idea. Ignoring that, it might work to use a UL compliant Enphase micro inverter + a 240VAC to 120VAC transformer.I am available for custom hardware/firmware development
Re: Suppliers and feedback on 120VAC micro inverters for use with PV panelsI'll let others point out that there are a variety of reasons why this isn't a good idea. Ignoring that, it might work to use a UL compliant Enphase micro inverter + a 240VAC to 120VAC transformer.
Whereas it would be better quality equipment, the installation would be subject to the same legal and technical problems.
- 228 Forum & Website
- 618 Discussion Forums/Café
