help wind low wind generator system
Charrlie1264
Registered Users Posts: 1
I just bought a low wind area 1-3 wind generator off of ebay. Its 800 watt. I set it up on a 20 ft pole but it want even rotate the baldes. They said this unit should rotate at 2 mph and generate at 5mph. any ideas. thanks for you help
Re: help wind low wind generator system
Welcome to the forum.
I'm sorry but you've been scammed. What you bought is called "junk".
Have you ever heard the phrase "you can't squeeze blood from a rock"? Same thing: there is no power in low speed wind so there is no possibility of harvesting what isn't there to begin with. 800 Watts? From 5 MPH? No chance. The blades would need to be forty feet long each to try and pull that much power from such low wind speed.
Have a look at Hugh Piggott's wind site: http://www.scoraigwind.com/
For DIY and other good info on turbine power you can't beat his stuff.
Otherpower is another good one: http://www.otherpower.com/ -
Hi Charrlie, Welcome to the forum.
I wish for your sake I could report that Cariboocoot was pulling your leg, but unfortunately he's not. Unfortunately your leg was pulled by the people who took your money for the "wind turbine" you now own. I too have been down that road and also learned the hard way. But we are far from being alone. Scammers have been unloading these small useless "wind turbines" on innocent, trusting folks for many many years, and so far no one has killed them. For some reason the law is protecting them.
If they won't take it back, all you can do is write it off as a learning experience.
In my case it wasn't a total loss, as I was able to use the alternator on my micro micro hydro system, but for wind? A sad joke, on me, many others, and now you. :grr:cry: -
Can you post a link to the one your bought?Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
My rule of thumb for wind power, if you have to tie your hat onto your head, EVERY time you go outside (or it blows off) then you have enough wind for power. 99% of people who "think" they have enough wind, don't.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
