Generator inlet
                    Joe94
                    Solar Expert Posts: 42 ✭
                    What are off griders using for a 110v generator inlet? I would like to use A power max 30 amp transfer switch. All the generator inlets at the local hardware store are 240v. A quick google search lead me to a few but the all seemed to be rated for 15amp. I'm sure my inspector is going to want it to be UL listed as well.
            Re: Generator inlet
I have a 240V transformer I plug into my 110 generator, and use a 240V electric range outlet. I can then plug my inverter into any of 3 different generators, depending on which one is functional at the time. (one always starts but has broken mounting bolt, one won't start below 30F, one uses gasoline.)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
            Re: Generator inlet
Are you looking for manual or automatic? There is a wide range of options.
            Re: Generator inlet
I'm looking at the PowerMax 30amp automatic transfer switch. I need to find a wall inlet that I can use to plug my generator into it.
 - 232 Forum & Website
