Generator inlet
Joe94
Joe94 Solar Expert Posts: 42
What are off griders using for a 110v generator inlet? I would like to use A power max 30 amp transfer switch. All the generator inlets at the local hardware store are 240v. A quick google search lead me to a few but the all seemed to be rated for 15amp. I'm sure my inspector is going to want it to be UL listed as well.
    Re: Generator inlet
    I have a 240V transformer I plug into my 110 generator, and use a 240V electric range outlet. I can then plug my inverter into any of 3 different generators, depending on which one is functional at the time. (one always starts but has broken mounting bolt, one won't start below 30F, one uses gasoline.)
    BB. Super Moderators, Administrators Posts: 33,743 admin
    Re: Generator inlet
    Are you looking for manual or automatic? There is a wide range of options.
  • Joe94
    Re: Generator inlet
    I'm looking at the PowerMax 30amp automatic transfer switch. I need to find a wall inlet that I can use to plug my generator into it.
