Erasing internal Data log for Tristar MPPT 60
DMJ72
Solar Expert Posts: 131 ✭✭
Good night,
I have searched the manual and online, and unless I am in dire need of glasses, I am unable to find out how to erase the internal data log. I have spurious entries due to controller resets and config changes. Would like to clear them out and start fresh.
The push button only resets a fault, and the menu will reset AH values and min/max battery values from the display =
"This display screen can be used to reset the reset-able Ah value. Additionally, this operation will reset the battery mini- mum and battery maximum values displayed in the Operating Displays. Hold the right arrow pushbutton for 2 seconds.."
Anyone know how?
Anyone know how?
Re: Erasing internal Data log for Tristar MPPT 60
Do you have "Ms view" installed on your computer? -
Hi Slappy,
Yes I have it installed but do not see any way to erase the log. I got this reply from Morningstar's tech support this afternoon :
"Hello David, Unfortunately, the TriStar Data Log can not be cleared."
Their correct. Just got finished searching my self could not find it. It been along time using msview. I thought that it can be done. My bad my mind is getting to old. -
There is a portion of the log that can be reset, but you cannot erase the whole thing.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
