morningstar tristar mppt 45
jimbob01
Solar Expert Posts: 63 ✭✭
Re: morningstar tristar mppt 45
no.............................................. -
As Niel said, no.
Don't go there if you value the controller. -
ok thanks guys.. just thought it might have a 10% tolerance or so jim -
Not to mention even though the rated Open Circuit Voltage may add up to 151.23, on cold and edge-of-cloud days you will see that voltage rise 10% or more. My OCV is 100.2 but I have seen it as high as 113v occasionally on those cold bright days.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
Re: morningstar tristar mppt 45can i safely put in 151.23v in to the tri star 45 mppt its rated at 150v input
No but why don't you split the array into 2 strings. -
yes splitting the array in to 2 strings was my plan...2 mstar 45s each with 3 sharp 235s in with an option to add 1 later thanks for the reply
- 228 Forum & Website
- 618 Discussion Forums/Café
