Chinese Charge Controllers
lazza
Solar Expert Posts: 336 ✭✭✭
HI
I have to confess a sin. I've bought some chinese charge controllers because they were very cheap
Now they work, and do the job. However, having studied their charging profile. Although it says that absorption is at 28.5V and float at 27V... really absorption is at 26.5V for half an hour and then drops down to 25.5V. They carry on supplying power and charging, but... the batteries at the end of the day are only at 24.8V (80% charged i suppose)..... whereas experimenting with a Xantrex C40 leaves them fully charged at 25.2V.
My question is: Is there any way of fooling these charge controllers into giving 2V more? so that the batteries are charged at more adequate voltages?
Re: Chinese Charge ControllersMy question is: Is there any way of fooling these charge controllers into giving 2V more? so that the batteries are charged at more adequate voltages?
Maybe. Do they have temp compensation? Do they have settings for different types of battery? Do they have any adjustments at all? Can you open the units and see if there are any dip switches or potentiometers?
Any of the above may sometimes be used to fool a charger.
Mmm doesnt seem to have any of what you've mentioned- here's a picture of the circuit board: Attachment not found. -
Learn the lesson, throw it out, get a good one. -
what does the exterior look like.? Brand?
I think I might have one of those with the 10 or so 'after dark' light activation settings. Mine seems to do a better charge job. Will try to get #'s this weekend, and report. On an RV 12 v batt.
Here it is- yes it's with those 10 or 20 light activation settings for the 12V/24V direct loads: Attachment not found. -
Lazza, my meter at the batt posts was 13.75v in float so for your bb i should be getting ~ 27.5v Float. no load on it so unable to check Absorb voltage.
They're cheap enough to buy a second one...no?
EVERYTHING IS MADE IN CHINA.......
Or the Philippines, Tawain.......
You will only find roughly under 10% of solar products made in america, canada, or germany...
Such as Concorde Batteries, Rolls, or SMA.........
Dont feel bad.
Even if it is assembled in the US or canada, the parts are probably more than likely Chinese. Like canadian Solar panels, they are literally a yingli panel that is rebadged for canadian solar, they are the same cells!
Just research better, for $30 more than the cheapest controller there is a better one out there...... -
Northern Arizona Wind and Sun sells the C35 for $83, pretty darn cheap...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 234 Forum & Website
