Solar cell record: Conversion-efficiency record for a two-junction solar cell measured u
Re: Solar cell record: Conversion-efficiency record for a two-junction solar cell measur
And it uses cheap and plentiful gold as the back plating to enhance reflectivity.Scientists have announced a world record of 31.1 percent conversion efficiency for a two-junction solar cell under one sun of illumination.SMA SB 3000, old BP panels. -
Funny how that works, innit? The race to higher efficiencies and the race to more practical solutions often do not have much to do with each other.And it uses cheap and plentiful gold as the back plating to enhance reflectivity. -
Well sometimes in practice once the scientists have built a very expensive Proof Of Concept, the engineers will be able to find a more economical way to get close to the same result.Funny how that works, innit? The race to higher efficiencies and the race to more practical solutions often do not have much to do with each other.SMA SB 3000, old BP panels. -
It should work very well on the planet Vulcan -
Sometimes, yes; sometimes, no. But we try.Well sometimes in practice once the scientists have built a very expensive Proof Of Concept, the engineers will be able to find a more economical way to get close to the same result.
