making 2/00 cables need lugs
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I am making some cables using 2/00 welding cable to go from the Batt. Manufacturers buss barr to the CC etc.
I got some good copper lugs for this project but found that they have 1/2 inch holes and the buss barr has 3/8" diam. holes & bolts, so now I am looking for lugs with 3/8" holes.
Tried all the local supply places and there is nothing available that gives at least > 1 inch contact between the cable and the lug. Lots with short connections < 1 inch.
Any recommendations for a Net Vendor with a suitable lug?
Re: making 2/00 cables need lugs
Try Mc Master Carr supply . They have a lot of lugs. I ended up making mine out of tinned copper pipe.
But be warned - the welding cable has very fine strands, and needs a good lug, and good compression to fuse the wires together and to the lug. Often, the fine strands work themselves loose........Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This where I get mine, Free Shipping, figure that into your cost per lug. If your buying in bulk you can save more. They also make cables for $1.00 per lug with heat shrink. They do a nice job.
http://shop.genuinedealz.com/Marine%20Electrical%20Supply/ -
I just bought 3/8ths luggs from naws, about 38 of them for 4/0 wire. I needed 5/16.
Cheers
gww -
waytekwire has a large selection of lugs and great prices on MRBF fuses (for the Blue Sea type battery post fuse holders)
- 227 Forum & Website
- 617 Discussion Forums/Café
