generator life
Registered Users Posts: 12
New guy here, returning.
I have the opportunity to buy a Yamaha EF3000ISEB that's still under warranty with an estimated 200 hours use. I would use it as an offgrid backup.
It seems to be a good model from my research and it's about half of retail price.
What I'm asking is: what is the lifetime expectation (number of hours) for this generator? Does anyone here have knowledge of this?
Thanks in advance!
Welcome!
  • Solar Expert Posts: 2,490 ✭✭✭
    Re: generator life
    gino45 wrote: »
    Thanks in advance!
    Anything used is always a chance, on the other hand I had a new Honda EU 2000 engine fail out of the box. They put a new motor in it, never missed a beat after that . 200 hrs is just a few oil changes, The Yamaha and the Honda 's seem to be on par with each other and some are reported to have as many as 5,000 hrs.
    I'd go for it.
  • Super Moderators, Administrators Posts: 33,654 admin
    Re: generator life
    I would plan on 2,000 hours with good maintenance (regular oil changes)... Marc (Cariboocoot) has a small eu1000i that is around 6,000 hours and beginning to use oil (as I recall).
  • Solar Expert Posts: 341 ✭✭✭
    Re: generator life
    Known brand, I would agree, an unknown brand or a home depot hurricane special may have a lot lower life.
    Re: generator life
    Test before buying. Take a tool or 3 and plug them all in to make sure it will handle them, like a 10A Makita compressor, 10A skill saw and a 1500 watt space heater. If it them all without failing, it should be ok. I got mine used and have a few hundred more hours on it so far, part of that was one week of tools for the work crew as listed for testing
  • Solar Expert Posts: 547 ✭✭✭✭
    Re: generator life
    Concur with Bill, I have had several EU1000 and EU2000s' and got about 2,000 hours out of them with frequent oil changes.
    Never had much long term success rebuilding one.
    These small Honda genset inverters are bullet proof. I keep one on my Ranger for ranch work and before I put the big system in to power the new house, I ran the old house with two of them for years.
  • Solar Expert Posts: 1,485 ✭✭✭✭
    Re: generator life
    I have an EF3000is. Good so far, but only have about 500 hours on it.
    I am pleased with it. Very quite. I think the EB boost feature is a joke and would not pay a dime extra for it. It sucks max of 500 watt boost from the small starter battery. Not much help for even a refrig startup surge.
  • Solar Expert Posts: 468 ✭✭✭
    Re: generator life
    I have the big boy Yamaha model (the 6300isde) with a little less than 300 hrs.
    So far it has performed well. I service it (oil change, spark arrestor & filter clean) every 75 hrs.
    It's an expensive beast (I probably would be fine with the 3000 version you are considering). I can convert it to autostart charge my bank if need be. However, it is not evident to me, yet, if the latter feature is worth the effort.
    If you say it's a good price, it's been serviced regularily, only used periodically over 1-2 years (200hrs), and a mechanic confirms that it is sound, I'd say go for it 8)
    Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid.
  • Banned Posts: 1,807 ✭✭
    Re: generator life
    gino45 wrote: »
    The generator itself will last for a long time. The engine is what will wear out. The Yamaha MZ175 engine is a consumer class engine in the same category as the Honda GC-series. They are not meant for long continuous duty operation like the Honda GX is. So the engine life is going to depend on usage. If you run it at or near full load all the time expect in the range of 500-1,000 hours from it. If you operate it at light loads expect around 2,000 hours.
    If you plan on using it for your primary off-grid generator so it's going to run at full load on battery charging duty I would suggest a more robust unit. If you plan on using it as a backup for your primary generator I would say it's probably a pretty good deal.
    Chris
Welcome!
