Panel mounting- question about frames
westend
Solar Expert Posts: 46 ✭
Hi,
First post here and I did search for the answer before starting this thread: Can I support and mount an MX-Solar 235w panel (39 1/2" x 65 1/2") on the short side ends, only, or do I need to support the long sides of the frame? This single panel will be mounted on the roof of a travel trailer. I am building my own mounting system that allows tilt in four axis' and mounting on the short frame sides affords an easy design. Thanks for any help.
Re: Panel mounting- question about frames
Welcome to the forum.
I'm not familiar with that brand, but it ought to have at least a data sheet for it including mechanical recommendations.
Quite often panels are simple bolted at four points to two long rails (one 'top', one 'bottom') along either the long or short sides (depending on whether it is landscape or portrait mounting).
The panel frame itself should be self-supporting, whether the mounts are on the long or short sides.
This is why you need to check the maker's recommendations, though. -
Re: Panel mounting- question about framesCariboocoot wrote: »Welcome to the forum.
I believe the panel's frame is robust enough to support itself but will look at Mfg.'s data sheets to see if the construction will allow. My initial feeling is that it will be OK but I've seen the MO of "it should be OK" fail many times. FWIW, this panel is no longer being built in the US, MX-Solar having closed their stateside plant. The company still has a fairly large Mfg. base and operations in Europe. -
One clue would be if it has mounting holes drilled in the short sides and the long sides. If it has holes only in the long sides (or no holes at all) I'd be suspicious. -
Re: Panel mounting- question about framesCariboocoot wrote: »One clue would be if it has mounting holes drilled in the short sides and the long sides. If it has holes only in the long sides (or no holes at all) I'd be suspicious.
I think this is good info, I know the Evergreen and Suntech instructions (for the panels I have) do NOT allow for short edge mounting, They both have grounding and weep holes on the short edge.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Panel mounting- question about framesThe frame has identical holes drilled with standard separation (2 1/4" OC) between, on all the frame pieces, both short and long. There are two pairs of these holes on each frame section.
That is a very good sign.
Sounds like they were meant for either portrait or landscape orientation.
Still check the data sheet though. Some panels require stiffening members if turned 'round (more flex across the long axis even if it is 'rigid'). For example, Kyocera has some different models of the same panel with an extra 'rib' built in. -
Re: Panel mounting- question about framesCariboocoot wrote: »That is a very good sign.
Were you planning on putting rails lengthwise beneath the panels, or merely mounting points on the two edges?
It never hurts to toss up some photos of either the proposal or the effort. There's lots of discussion about mounting going on around here. Usually it gets put in the installation section, but we're not that picky. -
Re: Panel mounting- question about framesCariboocoot wrote: »Were you planning on putting rails lengthwise beneath the panels, or merely mounting points on the two edges?
Cool. The mounting has a full length 1 1/2" x 1 1/2" 6061 aluminum angle along the short sides. This angle is hinged to the panel frame short sides with two 2 1/2" SS hinges. When the panel is flat, it rests inside a full-length "U" channel that is glued and screwed into the roof. I am going to install some gasketing material inside the "U" channel so that the panel frame is not just riding on the two pins of the mounting but will be against an absorbent material for the length of the short sides. I can replicate this for a middle span, also, if needed.
These are the views from the bottom side of the panel.
Complete mount, one side:
Hinge points:
Hinged in one axis:
Hinged in second axis:
I don't understand. you found mounting holes and the chose not to use them? rather you broke the integraty of the box frame of the panel? That doesn't make sense to me...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I wouldn't personally use the solar panel frame as a structural part of your mount like you appear to have done. I believe the hinges should be attached to a mount that would be adjustable and secureable with or without a solar panel on it, then bolt the panel to the mount. -
Re: Panel mounting- question about framesI don't understand. you found mounting holes and the chose not to use them? rather you broke the integraty of the box frame of the panel? That doesn't make sense to me...
Re: Panel mounting- question about framesVolvo Farmer wrote: »I wouldn't personally use the solar panel frame as a structural part of your mount like you appear to have done. I believe the hinges should be attached to a mount that would be adjustable and secureable with or without a solar panel on it, then bolt the panel to the mount.
All modules I'm familiar with state in their warranty that you cannot drill any holes or modify the module frame in any way. Can't paint them either. Sometimes the spec sheet or mounting instructions require the mounting support to be only in certain areas to meet the snow load spec. Generally, if there are two sets of holes at each end, you have to put the support somewhere between them. Of course, if you don't care about the warranty - do whatever you want. -
Re: Panel mounting- question about frames... I don't really see how these 12-5/32 holes impact frame integrity. Can you explain your reasoning on that?
If they were just holes, you just voided your warranty, but they are more than hole they are pivot points for the weight of the panel. Some engineer somewhere had to figure the proper point to secure the panels and signed off on having a hole in that spot, based on the weight of the panel and the orientation of the hole to the weight, based on stresses likely to be present. Evergreen says to use 2 supports up to a 70 mph max wind and 3 or 4 for more than 70 mph (I'm not sure if 70 was the wind speed but since your mounting these on a moving vehicle they are likely to see high wind speed)Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Panel mounting- question about framesIf they were just holes, you just voided your warranty, but they are more than hole they are pivot points for the weight of the panel. Some engineer somewhere had to figure the proper point to secure the panels and signed off on having a hole in that spot, based on the weight of the panel and the orientation of the hole to the weight, based on stresses likely to be present. Evergreen says to use 2 supports up to a 70 mph max wind and 3 or 4 for more than 70 mph (I'm not sure if 70 was the wind speed but since your mounting these on a moving vehicle they are likely to see high wind speed)
I don't expect you to hit the road with the panel up, but there is vacuum to be considered and alluminum doesn't do well with vibrations. I don't think it will lead to the glass cracking, but you might well crack the aluminum....
...I'm a cyclist, and there is an american bicycle company who keep their name "Cannondale" they pioneered alumbinum bike frames but after many early problems earned the name "Crack-N-Fail" after they had a higher than average failure rate in the frames (bottom brackets and tension tube between the BB and headset) They keep the name and offered a life time warranty on their frames and now have a very good reputation.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Panel mounting- question about framesI don't expect you to hit the road with the panel up, but there is vacuum to be considered and alluminum doesn't do well with vibrations. I don't think it will lead to the glass cracking, but you might well crack the aluminum....
Trying to improve structural stability of any metal installation is easy if weight, time, and budget are not considered. Fortunately, when dealing with a flat fixture that weighs 40 lbs, and is being mated to another surface that is flat, choice of materials broadens and design can be simplistic. Look at your racking systems for PV that are available, they are very simple in a broad sense, a couple of rails and some tie down clips. I'm using 6061 aluminum in most of this, similar material to standard racking, or better. Those hinge holes I drilled are now filled with stainless steel bolts and have a backing plate afforded by the hinge. The immediate area's structural strength has increased by an order of 10, I'm thinking. Will this create stress on the panel frame in those areas when the panel is tilted, ....yes. Will the frame endure the increased load in those areas....I believe it will. The rating of the panels snow load strength is 5400 pa. That allows a lot of leeway in design, it is nearly twice the strength of IBC rated roofs and bespeaks the module's build characteristics for overall load bearing.
As far as dealing with aerodynamics and vibrational stresses, I'm trying to deal with it as much as possible but anecdotal reports of other RV'ers show that it isn't an issue at all. When you look at the possible forces involved (70 mph wind, the occasional hole/bump in the road), there shouldn't be excessive worry. The wind strikes the panel at it's edge when traveling and the incidental lift or compression is not that great. The road surface oscillation is greatly absorbed by the tires and the vehicle structure. If this weren't true, our highways would be littered with roof top racks, ladders, skis, and bikes.
FWIW, I'm not a novice with metal working and excessive forces. The safety of more than a few folks and the security of millions of dollars of product have been entrusted to my work. Think petro-chemical tankers or food production facilities. I hope my track record in those, and other situations, continues and that I can share a decent way to allow for tilting on top of an RV. I'm not going for a Cannondale, nor a Huffy, more like a Jamis Xenith http://www.bicycling.com/node/60381 -
Re: Panel mounting- question about framesMost of them attach a "Z" bracket in each corner, run in two screws, cover the foot with sealant, and call it a day.
With Z-brackets, the panel is mounted to the bracket using mounting holes on the bottom of the panel. That's the same way the panel is mounted to stationary structures.
Mounting holes are located at some distance from the short side, which increases structural strength compare to your method.
They don't use panel's frame as a pivot. IMHO, panel frame by itself is not strong enough to withstand pivoting.
Since it tilts in only one direction, you will have to always position your RV so that the panel would tilt to south, otherwise the pivot will not do you any good. -
The main structural concern with modules is in fracturing the tempered glass. Flex the module too much by say mounting it on the short ends and piling it full of snow and one crack in the glass causes the whole thing to fracture into little bits. Fracking is bad! -
Re: Panel mounting- question about framesThe main structural concern with modules is in fracturing the tempered glass. Flex the module too much by say mounting it on the short ends and piling it full of snow and one crack in the glass causes the whole thing to fracture into little bits. Fracking is bad!
Re: Panel mounting- question about framesWith Z-brackets, the panel is mounted to the bracket using mounting holes on the bottom of the panel. That's the same way the panel is mounted to stationary structures.
Man, tough room. If some of these "can't do its" can be based on some knowledge of the specific materials and this mount construction vs conventional vehicle mounting, it would be appreciated. -
Re: Panel mounting- question about framesMan, tough room. If some of these "can't do its" can be based on some knowledge of the specific materials and this mount construction vs conventional vehicle mounting, it would be appreciated.
That's how you engineer things. You try to think of everything that can go wrong, then do try to figure out if what you're doing is able to withstand those bad things. And, in the end, things that you didn't think about get you
When you "hold" panel by the short sides, you double the unsupported span of the long side of the aluminum frame compared to hole mounting. Therefore, the wind load (and snow load too) that they can support now is about 1/4 of what it would be if it was supported at the mounting holes.
Pivoting puts a twisting force on the short side of the frame. I don't think it ever meant to withstand twisting.
These are two specific things that make your construction weaker than the Z-bracket mount. -
Re: Panel mounting- question about framesThat's how you engineer things. You try to think of everything that can go wrong, then do try to figure out if what you're doing is able to withstand those bad things. And, in the end, things that you didn't think about get you
OK, thanks for your input on the load bearing and "twisting" regarding the tilt mount. That we can discuss. The module in it's original configuration has mounting through holes in the short side, paired-2 1/4" apart. These pairs are located at 9 3/4", 12" from the frame edge. The long side frame also has the same two pairs, spaced-2 1/4". located 15 3/4",18" from the panel edge. The shortest (not to a corner) unsupported span is 18" along the short side, the longest span is 32" along the longer side. The short side mounting brackets I made are at the same location as the mounting holes on the short side, same span length. If I support the long side span in the middle of the panel's span, the resulting two lengths are 32 1/2". I have not increased any of the lengths of unsupported span of the frame. In fact, in it's most used configuration (tilted from the short side corner), the frame is reinforced by the additional 1 1/2" angle pieces under the frame. FWIW, this modules load rating is 5400pa=112 PSF. This is almost double any residential building code regarding snow load for roofs.
I am not understanding your reference to twisting. There is rotation around the locking pins or at the hinge pins. -
I tend to think that the manufacturer's restrictions (like not drilling holes) are overly conservative and reflect the 25 year warranty they provide. When you have that long of a warranty period, I suppose you get a little paranoid about problems - and also a little overzealous about providing "outs" from it. -
Re: Panel mounting- question about framesI tend to think that the manufacturer's restrictions (like not drilling holes) are overly conservative and reflect the 25 year warranty they provide. When you have that long of a warranty period, I suppose you get a little paranoid about problems - and also a little overzealous about providing "outs" from it.
Re: Panel mounting- question about framesOK, thanks for your input on the load bearing and "twisting" regarding the tilt mount. That we can discuss. The module in it's original configuration has mounting through holes in the short side, paired-2 1/4" apart. These pairs are located at 9 3/4", 12" from the frame edge. The long side frame also has the same two pairs, spaced-2 1/4". located 15 3/4",18" from the panel edge. The shortest (not to a corner) unsupported span is 18" along the short side, the longest span is 32" along the longer side. The short side mounting brackets I made are at the same location as the mounting holes on the short side, same span length. If I support the long side span in the middle of the panel's span, the resulting two lengths are 32 1/2". I have not increased any of the lengths of unsupported span of the frame. In fact, in it's most used configuration (tilted from the short side corner), the frame is reinforced by the additional 1 1/2" angle pieces under the frame. FWIW, this modules load rating is 5400pa=112 PSF. This is almost double any residential building code regarding snow load for roofs.
I don't understand about the support in the middle. If you want to add the support, it must be connected to something, but you do not seem to have anything to connect it to except the frame itself.
It is quite possible that your panel is strong enough for your mounting, especially if it is designed to be mounted on the short side. However, if I were building this, I wouldn't count on the strength of the frame and would build a separate frame that would tilt as I want, most likely with some diagonal element(s) in it and then would mount the panel on top.I am not understanding your reference to twisting. There is rotation around the locking pins or at the hinge pins.
If you open it too wide, the hinge will start to twist the short side out of the panel. Depending on the strength of the panel, it may be enough to do it once to break it out. -
Re: Panel mounting- question about framesI don't understand about the support in the middle. If you want to add the support, it must be connected to something, but you do not seem to have anything to connect it to except the frame itself.
Yes, I agree, it would be stronger to mount the module on a secondary frame and then provide for tilting. However, there is considerable cost and time involved for that and is the benefit worth the trouble? Secondly, an additional frame would raise the module another 1" or 2" over the roof. This is more drag, hence, more force on the mounts and module and less MPG.
I am maybe starting to realize that all module construction may not be alike. There is no way on this Planet that the frame would come apart by hinging in any direction. I am guessing that the frame edges will not even deflect a mm. This MX-Solar module is constructed of an outer 1 1/4 x 1 3/4" x 3/4" "U" channel. The cells and acetate backing lie on that smaller edge of the back of that channel, the 3/4". On top of the acetate back and inboard of the "U" channel is another piece of formed aluminum that must be pressed into place during manufacture. So what I have in this module is a frame within a frame and the cells with backing are between the two frame edges. Does that make sense? -
Re: Panel mounting- question about framesHowever, there is considerable cost and time involved for that and is the benefit worth the trouble?.
It depends. If concerned about time and effort, I would probably go with two fixed panels mounted flat. In nearly any situation that would give me more power than one tilter, and I wouldn't need to go yo the roof to tilt it.Secondly, an additional frame would raise the module another 1" or 2" over the roof. This is more drag, hence, more force on the mounts and module and less MPG.
Not necessarily. You can build a frame from aluminum angles, then mount it so that the "flat" side faces the roof and mount the panel completely inside the frame. The whole construction could be made no thicker than 2", may be 2 1/4". That is actually less than what you have now.I am maybe starting to realize that all module construction may not be alike. There is no way on this Planet that the frame would come apart by hinging in any direction. I am guessing that the frame edges will not even deflect a mm. This MX-Solar module is constructed of an outer 1 1/4 x 1 3/4" x 3/4" "U" channel. The cells and acetate backing lie on that smaller edge of the back of that channel, the 3/4". On top of the acetate back and inboard of the "U" channel is another piece of formed aluminum that must be pressed into place during manufacture. So what I have in this module is a frame within a frame and the cells with backing are between the two frame edges. Does that make sense?
The construction of modules differ. Some are stronger and some are weaker. Most modules are 2" thick, so yours is a little bit on a thinner side. The thickness of the frame metal is may be only 1/16". They are designed to be attached to a fixed base. -
Re: Panel mounting- question about framesIt depends. If concerned about time and effort, I would probably go with two fixed panels mounted flat. In nearly any situation that would give me more power than one tilter, and I wouldn't need to go yo the roof to tilt it.Not necessarily. You can build a frame from aluminum angles, then mount it so that the "flat" side faces the roof and mount the panel completely inside the frame. The whole construction could be made no thicker than 2", may be 2 1/4". That is actually less than what you have now.The construction of modules differ. Some are stronger and some are weaker. Most modules are 2" thick, so yours is a little bit on a thinner side. The thickness of the frame metal is may be only 1/16". They are designed to be attached to a fixed base.
I'm just about finished discussing my efforts with the tilting mounts. There seems to be a commonality of "you have to do it this way or it won't work". Most of the comments have no basis in any real-world metal working, any knowledge of module construction and engineering principles, or even bother to read through my original posts and pictures to see what I'm doing. I'm done defending the attributes or exploring the lack of in this thread. Thanks to those with valid critiques.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
