New Cree LED Light Bulbs
Steve961
Solar Expert Posts: 93 ✭✭✭✭
Not sure if anyone else has noticed, but Cree has just released their new residential light bulbs. The bulbs are efficient, omnidirectional, traditionally sized, and relatively inexpensive. They seem to be available exclusively through Home Depot, at least for now, and can be ordered online.
The 40 watt equivalent has the following specs:
6 Watts
450 Lumens
25,000 Hour rated lifetime
2,700K color temperature
Lights instantly, omni-directional
Mercury free
Safety-coated glass
Dimmable
Price of $9.97 at Home Depot
Here are links to two of them at Home Depot:
6W (40W) Warm White A-Type Replacement LED Bulb
9.5W (60W) Warm White A-Type Replacement LED Bulb
At my off grid cabin I plan to replace all of my 9W (40W) Phillips CFLs with these. Most of my electrical usage, especially in winter, is lighting, so I should see a significant energy savings with these. It'll hopefully postpone my needing to get a bigger battery someday. The only problem I'll have to work around is my SureSine inverters 8 watt autosensing threshold - the Phillips CFLs used just enough energy to trigger the inverter.
Steve
6 Watts
450 Lumens
Mercury free
Safety-coated glass
Dimmable
Steve
Re: New Cree LED Light Bulbs
Lucky Americans.
Try buying an LED bulb in B.C. - $30, and it's not even a big one. -
those look promising, about the same price as the 180 deg HD brand of bulbs. (that I just bought 2 of)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: New Cree LED Light BulbsCariboocoot wrote: »Lucky Americans.
Actually, Philips has a good bulb out that I purchase recently for about $20 at Home Depot (in BC too, yaaaay). I am quite pleased with it, and is a little cooler than their endura LED's at 3000k. It's 10.5 watts and puts out 800 lumens. It's not suitable for dimmers or enclosed fixtures, however, but is OK for damp locations. Most of the LED's are not to be operated in enclosed fixtures. Only one I know of is from Switch Lighting, which uses liquid cooling.
I'm sure prices of the LED's will keep coming down over time as well. -
Re: New Cree LED Light Bulbsnortherner wrote: »Actually, Philips has a good bulb out that I purchase recently for about $20 at Home Depot (in BC too, yaaaay).
I wanted to buy some in HD, but I didn't. I thought they were more like $24. In BC, with HST will be close to $30.northerner wrote: »I'm sure prices of the LED's will keep coming down over time as well.
I'm waiting for this. For now, I think CFLs are more economical. They use slightly more power, but cost several times less. -
Northerner, which one? http://www.homedepot.ca/webapp/wcs/stores/servlet/SearchView?D=philips&Ntt=philips&langId=-15&Dx=mode+matchallpartial&storeId=10051&Ntx=mode+matchallpartial&catalogId=10051&Nty=1&s=true&N=172458
Re: New Cree LED Light BulbsI wanted to buy some in HD, but I didn't. I thought they were more like $24. In BC, with HST will be close to $30.
No, I didn't factor in that darn HST! I paid $20 on the island around Xmas.I'm waiting for this. For now, I think CFLs are more economical. They use slightly more power, but cost several times less.
I switched all my open air bulbs to LED and I use the existing CFL's I was using for enclosed fixtures. I think that the cost of bulbs is minimal when you compare with the price of putting in an entire solar system. I really don't care for the CFL's much, particularly in locations where the light is on for short periods of time, or in close proximity to people. So far, the Philips Endura LED is my favorite. Good color and light dispersal. It does have a minor hum, which could be annoying to some. -
Re: New Cree LED Light BulbsFor now, I think CFLs are more economical. They use slightly more power, but cost several times less.
I replaced the ceiling light in my garage/music studio with a 60W equivalent LED, and other than its half second delay in starting up, which is just about long enough to think that it may be burned out, I like it fine. -
Re: New Cree LED Light BulbsI replaced the ceiling light in my garage/music studio with a 60W equivalent LED, and other than its half second delay in starting up, which is just about long enough to think that it may be burned out, I like it fine.
This is why I still have incandescent bulbs in my tool shed; CFL's at -40C don't light up until Summer comes. -
Re: New Cree LED Light BulbsNot sure if anyone else has noticed, but Cree has just released their new residential light bulbs. The bulbs are efficient, omnidirectional, traditionally sized, and relatively inexpensive. They seem to be available exclusively through Home Depot, at least for now, and can be ordered online.
I see that they are also offering 5000K lamps that may be suitable for outside use or any application where the warm, incandescent-like appearance is not required. Those seem to be marginally more efficient (9watts instead of 9.5 watts for 60 watt equivalent.)SMA SB 3000, old BP panels. -
Re: New Cree LED Light Bulbs6 Watts
450 Lumens
Mercury free
Safety-coated glass
Dimmable
These specs are missing one of the 4 most important specs: CRI. A quick googling didn't turn it up. Does anyone know the CRI for these emitters? -
Re: New Cree LED Light BulbsThese specs are missing one of the 4 most important specs: CRI. A quick googling didn't turn it up. Does anyone know the CRI for these emitters?
Look at the actual Cree site, and see that it is 80. Not great, but not outrageous either.
There are definitely better. The Phillips L Prize model 420244 lists a CRI of 92 and a list price of $50 (color temperature unknown), while the less expensive Phillips A19 size bulbs have a CRI of 81 at 2700K.SMA SB 3000, old BP panels. -
Re: New Cree LED Light BulbsLook at the actual Cree site, and see that it is 80. Not great, but not outrageous either.
Darn, that's too bad. 80 CRI isn't good enough to avoid causing me problems. -
Re: New Cree LED Light BulbsDarn, that's too bad. 80 CRI isn't good enough to avoid causing me problems.SMA SB 3000, old BP panels.
- 228 Forum & Website
- 653 Solar Water Pumping
- 619 Discussion Forums/Café
