Battery question
Ronin2004
Registered Users Posts: 8 ✭
Ok so we have decided on having about a 1 kw continous sytem design. using a 24 volt battery bank
I have calculated that that 1000 w*24 hours *1/24 volts*1/.85*1/.5= 5647 AH so to find how many batterys i need i devide that number by the @20 hr amp hour rate of my battery
this is the battery the group wants to go with
Smart Battery™ SB100
12V 100AH Lithium Ion Battery
Nominal Voltage: 12.8V
Amp Hours: 100
1000 Cranking Amps
300 min @ 20A
120 min @ 50A
Max Continuous Discharge 100A
after doing the peukerts equation i find that value to be only 2.73 ams
20=(50*(50/2)^(1.05-1))/x^1.05
does that mean it would take 2068 batteries for this system
Amp Hours: 100
1000 Cranking Amps
300 min @ 20A
120 min @ 50A
Re: Battery question
If you want to output 1kW for 24 hours, you need to store 24kWh /0.85 = 28kWh
12V 100AH battery discharged to 50% will give 12*100*0.5 = 0.6kW
So, you need 28/0.6 = 47 batteries. 48 is probably a better number. -
Why you should always do math in order.
1kW * 24 hours = 24 kW hours.
Conversion efficiency of inverter 90% = 26.7 kW hours
Inverter consumption in 24 hours (assuming a reasonably good inverter) = 576 Watt hours
Needed stored energy: 27,276 Watt hours. Round up for losses.
28 kW hours @ 24 Volts = 1167 Amp hours
Battery bank @ 50% DOD = 2334 Amp hours. Round up to nearest available size. Calculate recharging capacity from that.
Ridiculous to try and get that much capacity from 100 Amp hour batteries. It will be a mare's nest of wiring.
But hey; feel free to do any way you like.
Batteries that give specs on cranking Amps and reserve capacity are probably not suitable for RE applications. -
Re: Battery question......
Peukerts is designed for Lead Acid batteries. Applying it to LiOn will give vastly different results. Same idea, but the
ratios are different.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Battery questionCariboocoot wrote: »Battery bank @ 50% DOD = 2334 Amp hours. Round up to nearest available size.
2400.
24 series of 100AH batteries.
2 batteries per series.
24 x 2 = 48
Same result as mine
24 series probably not going to work anyway -
Re: Battery question2400.
24 x 2 = 48
Same result as mine
Uh, two 12 Volt 100 Amp hours in series to get 24 Volta & 100 Amp hours.
Twenty-four such strings in parallel to bring the capacity up to 2400 Amp hours.
It's that last one that's ludicrous; there is no way those batteries are going to share current equally no matter what.
- 228 Forum & Website
- 618 Discussion Forums/Café
