Replacing glass on broken panel?
CVN-71
CVN-71 Solar Expert Posts: 54 ✭✭
I have a 205W panel with broken glass. All the cells are still good. Has anyone taken glass out of a broken panel and replaced it? I was thinking I could remove the frame, then perhaps purchase a piece of safety glass from the glass shop and then silicone it all back together. How do the DIY'rs do it? My plan is just to use the panel on a shed, so what it looks like is not important. Any ideas appreciated.
    Re: Replacing glass on broken panel?
    My advice is: don't even try.
    In attempting to remove the glass you most likely will damage the cells underneath (which are laminated to the glass). Your best bet is to use some auto-grade windshield repair or UV proof silicone to seal up the cracks until you can replace the whole panel.
    There have been quite a few inquiries on the forum of this nature. If you search for broken glass site:wind-sun.com on Google you'll come up with a number of threads/posts about the problem and all the trials to overcome them. The results aren't very promising.
    DIY people kid themselves into thinking they're making a panel as good as commercial grade, that's how they do it. Any panel that can be easily taken apart and repaired will probably need to be over and over.
  • CVN-71
    Thanks, wasn't sure how the cells were attached. I might just get a piece of plexiglass and silicone it over the glass to waterproof it. Panel works great, but I'm sure the cracks have reduced output a little. Still, even with cracks and plexi, should be enought to keep a 12v battery charged for shed light needs.
    tks
    Photowhit Solar Expert Posts: 6,014 ✭✭✭✭✭
    I saw some epoxy on Ebay that appeared interesting, not cheap!. I forwarded it to the guy who I gave some 14 cracked glass panels. I'll hunt it up tonight for you. I'll PM if I onlyt find on Ebay.
    Well I'm stuck waiting on a phone call; The stuff is called "MAX 1618 EPOXY" from the 3 minute research 1618 is a bonding reagent for different types of Epoxy, easiest to do a google search (link) about half of the links come up with youtube vids and the other half are direct or click thru links to Ebay.
    The one seller I saw had 4 negatives having to do with shipping charges, nothing negative about the product. Might be worth a try. Let us know! There were some smaller quantities. Only the gal size info refers to solar panels. The smaller kits were @$30 + ship.
