Need To Pump 1,600 Gal per Day
DanS26
DanS26 Solar Expert Posts: 271 ✭✭✭
I currently use a 1,600 gal tank to gravity feed a drip irrigation system for my wife's extensive perennial garden. I fill this tank once a day using a small gasoline powered (Honda) pump.
I'd like to use a solar powered pump to fill this tank and thus would like to solicit suggestions from the members of this forum for a properly sized system for this application. The lift is approximately 20 ft., so I need a system to lift 1600 gallons 20 ft in about 6 hours (say 250 to 275 gals per hour). A float shut off would be nice also. This is not a pressurized system.
Thanks in advance for your advice.
23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring
  • tmarch
    tmarch Solar Expert Posts: 143 ✭✭
    Re: Need To Pump 1,600 Gal per Day
    Fairly simple to design a system that's a stand alone for this. 5 Gallon a minute is easily obtainable with 2 panels, marginal with 1 tho. My demonstation model will produce 10 gallons a minute at that head on 2 panels, here's that setup.
    Lorentz PS6000 controller
    Lorentz 600HR motor
    Lorentz HR14 Pump
    You wouldn't need the PS600 controller, but it's not a lot more expensve than the PS200 and offers some advantages.
    This system has the option of a float switch.
    I have a somewhat similar situation, about 2500 gallons, 160' lift, to supply a 300 tree orchard. I went with a standard well pump run off an inverter. Be glad you have such a low lift requirement, that saves a lot of power.
