Which Brand Submersible Pump To Choose?
pabloesguapo
pabloesguapo Solar Expert Posts: 116 ✭✭
I had my eye on a Grundfos 16 SQF-10, but I'm wondering if there might be a less expensive submersible pump that will give similar performance.
My well stats: 175' TD, 53' SL, Flow of 50+ GPM. My homeowners Association limits our wells to 15GPM. I'd like to get as close to that as I can.
From what I can figure, the 16 SQF-10 can provide about 15 GPM if I provide it with about 750 watts of DC power from PV cells. 4 PV cells at 185 watts apiece (740 watts total) should just about cover it, no?
Is there any other brand/model submersible pump out there that can match the Grundfos's performance at a lower price?
27 Kyocera panels, 6,500w
24 CG2 6v batteries, 48v, 630Ah
Midnite Classic 150 & Classic 150 Lite in "follow me" mode
(2) Outback fx3648 inverters
Generac ecogen 6kw backup generator
Mate3s
    Re: Which Brand Submersible Pump To Choose?
    Another thing to research is sand/sediment in your well water--Some pumps do better than others.
  • stephendv
    Lorentz is another brand that's quite popular as a direct solar pump. http://www.lorentz.de/
  • pabloesguapo
    Been trying to find those Lorentz pumps, but can't find anyone who will publish their prices. Any idea how much they cost?
    Mate3s
  • Ross
    Ross Registered Users Posts: 20 ✭✭
    Greetings: Back in December I rcvd a quote on a Lorentz PS1200 controller/HR pump for $2340. Hope this helps.
  • tmarch
    tmarch Solar Expert Posts: 143 ✭✭
    Lorentz is a modular pump, meaning that the controller, motor and pump are all seperate. For me that's a + as you don't have to replace them all if 1 fails and they seem to be as reliable as any pumps.
    check your messages
  • pabloesguapo
    Ok, grundfos or Lorentz, both can run on both ac or dc, right?
    Mate3s
  • tmarch
    Either will run on AC or DC with the correct interface.
    Grundfos is a bit simpler in this respect as you can use the 101 (I believe) control box that has a pigtail for 110 AC.
    Lorentz requires a seperate component that is basically a AC to Dc converter.
  • pabloesguapo
    Cool. Thinking pv cell primary, generator backup.
    Mate3s
  • Mangas
    We only use Grundfos on our ranch wells and underground tanks.
  • Texas Wellman
    Texas Wellman Solar Expert Posts: 153 ✭✭
    I have used several Lorentz pumps and really like the set-up so far. The ones I used can run on one single large panel as opposed to the grundfos which likes the higher voltages and thus more panels.
