Which Brand Submersible Pump To Choose?
pabloesguapo
Solar Expert Posts: 116 ✭✭
I had my eye on a Grundfos 16 SQF-10, but I'm wondering if there might be a less expensive submersible pump that will give similar performance.
My well stats: 175' TD, 53' SL, Flow of 50+ GPM. My homeowners Association limits our wells to 15GPM. I'd like to get as close to that as I can.
From what I can figure, the 16 SQF-10 can provide about 15 GPM if I provide it with about 750 watts of DC power from PV cells. 4 PV cells at 185 watts apiece (740 watts total) should just about cover it, no?
Is there any other brand/model submersible pump out there that can match the Grundfos's performance at a lower price?
27 Kyocera panels, 6,500w
24 CG2 6v batteries, 48v, 630Ah
Midnite Classic 150 & Classic 150 Lite in "follow me" mode
(2) Outback fx3648 inverters
Generac ecogen 6kw backup generator
Mate3s
Re: Which Brand Submersible Pump To Choose?
Another thing to research is sand/sediment in your well water--Some pumps do better than others.
Lorentz is another brand that's quite popular as a direct solar pump. http://www.lorentz.de/ -
Been trying to find those Lorentz pumps, but can't find anyone who will publish their prices. Any idea how much they cost?27 Kyocera panels, 6,500w
Generac ecogen 6kw backup generatorMate3s -
Greetings: Back in December I rcvd a quote on a Lorentz PS1200 controller/HR pump for $2340. Hope this helps. -
Re: Which Brand Submersible Pump To Choose?pabloesguapo wrote: »Been trying to find those Lorentz pumps, but can't find anyone who will publish their prices. Any idea how much they cost?
Lorentz is a modular pump, meaning that the controller, motor and pump are all seperate. For me that's a + as you don't have to replace them all if 1 fails and they seem to be as reliable as any pumps.
check your messages -
Ok, grundfos or Lorentz, both can run on both ac or dc, right?27 Kyocera panels, 6,500w
Re: Which Brand Submersible Pump To Choose?pabloesguapo wrote: »Ok, grundfos or Lorentz, both can run on both ac or dc, right?
Either will run on AC or DC with the correct interface.
Grundfos is a bit simpler in this respect as you can use the 101 (I believe) control box that has a pigtail for 110 AC.
Lorentz requires a seperate component that is basically a AC to Dc converter. -
Cool. Thinking pv cell primary, generator backup.27 Kyocera panels, 6,500w
We only use Grundfos on our ranch wells and underground tanks.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
I have used several Lorentz pumps and really like the set-up so far. The ones I used can run on one single large panel as opposed to the grundfos which likes the higher voltages and thus more panels.
- 234 Forum & Website
