Forum attached file size limitation.
RCinFLA
Solar Expert Posts: 1,485 ✭✭✭✭
Why limit .pdf attachments to such a small file size? (tiny 19.5 kB)
I have to convert any attached charts to jpg which forum allows to be a larger file size (253.9kB) .
The pdf charts, which contain vector graphics, would be must better view quality for a smaller file size then jpg.
Re: Forum attached file size limitation.
Actually that was the default that nobody had ever mentioned before.
I upped it to 800K, and I also disabled ZIP files upload, since those can have some unknown files or virus in them. -
Thanks!
(insert filler space here)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
test of file size... to attach
Well it looks like .XLS and .XLSX files are not allowed for uploading???
Re: Forum attached file size limitation.westbranch wrote: »test of file size... to attach
Should be able to now, let me know if it does not work. -
thanks,
XLS works but not XLSX
Apparently XLSX is a different MIME type than XLS, will have to find out what it is and fix it sometime today or tomorrow. -
Re: Forum attached file size limitation.Apparently XLSX is a different MIME type than XLS, will have to find out what it is and fix it sometime today or tomorrow.
is the XLSX format a secure version? -
XLXS appears to be a compressed (ZIP) version of standard XLS files that is automatically un-zipped by Excel. Still have not found a spec that works for it reliably.
- 611 Discussion Forums/Café
