pv to main DC disconnect wire size
jtdiesel65
Solar Expert Posts: 242 ✭✭✭
I'm planning to run 2-2-4 from each pole mounted combiner to the charge controllers and main DC disconnect (midnite solar 250). That means I have to reduce the awg 2 to awg 6 to fit the breakers. What are people doing for this? sometype of reducing lug wrapped in electrical tape?
I have two arrays, one is ~100 ft, the other ~140 ft. Each will be 12 suntech 170 in strings of two. voc 43.8v, operating 35.2v, short circuit 5.14a, operating 4.83a.
Re: pv to main DC disconnect wire size
Polaris lugs?jtdiesel65 wrote: »I'm planning to run 2-2-4 from each pole mounted combiner to the charge controllers and main DC disconnect (midnite solar 250). That means I have to reduce the awg 2 to awg 6 to fit the breakers. What are people doing for this? sometype of reducing lug wrapped in electrical tape?
see this thread for ideas that have been rejected & used
http://forum.solar-electric.com/showthread.php?t=12693
http://www.grainger.com/Grainger/COOPER-BUSSMANN-Splicer-Terminal-Block-1EF57Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Those would be my first choice if you need the splice to be insulated.Polaris lugs?
http://www.polarisconnectors.com/black.html
- 230 Forum & Website
