Sun PLUS wind
I currently have 2 small Kyocera panels (2X43w= total 86w) in a 12v system using a Xantrex C35 controller and am about to add Wind power (300-500w) at 12v.
Q: Will I need to add, say a C40 as a DIVERSION LOAD controller to manage the dump load, separate from the existing C35 CHARGE controller?
And what other equipment would I require to allow these two systems to work together to charge my 12v batteries (diodes, etc)
Thanks folks!
    BB. Super Moderators, Administrators Posts: 33,734 admin
    Re: Sun PLUS wind
    That is correct, you need the second charge controller configured as a "dump" or "diversion" type controller... Plus you will need some sort of resistive load (typically) for the controller to divert the excess energy into.
    Does the wind turbine come with a complete installation manual? Depending on the turbine, you will need other components--but usually nothing special (for example a switch to short the turbine output to "turn it off" if high wind is expected or you will be performing maintenance).
    Typically the turbine uses an alternator with it own integrated diode array (to rectify the AC into DC current). So a second diode is generally not needed.
  • System2
    System2 Posts: 6,290 admin
    Re: Sun PLUS wind
    Thanks, BB
    The turbine will be a 12v DYI Hugh Piggott build (6 ft probably) and I'd use 1 or 2 - 300w - 12v resistors as diversion load.
    I'll be installing a recifier - 85A likely.
    My main concern is operating the two systems together.
    Might there be any interference between them during operation?
    Re: Sun PLUS wind
    Thunder wrote: »
    ..... I'd use 1 or 2 - 300w - 12v resistors as diversion load....
    I've liked using car headlamps as 12V loads. Cheap, no cooling fans needed, and you can tell from a distance, if you are in diversion. Each high beam is about 50 watts.
  • waynefromnscanada
    Re: Sun PLUS wind
    And just a heads up - - unless you live in a perpetually very windy location, the odds are HUGE that you will only get any useful power from the wind turbine during wind storms. Been there, done that with small scale wind. Now I'm solar and pico hydro. Few and far between were the days when I got any useful charge at all from the small wind turbine, in spite of the salesman's pitch, while few and far between indeed, were the days when I didn't get at least some charge from solar.
