World's Highest Solar Powered Webcam
Steven Lake
Solar Expert Posts: 402 ✭✭
http://news.cnet.com/8301-17938_105-20114066-1/worlds-highest-webcam-could-use-a-sherpa/
Found this on TDW and thought you guys might find it interesting. Oddly enough, the setup is rather similar to my buddy's solar weather station setups.
Re: World's Highest Solar Powered Webcam
and here i thought the highest solar powered weather cam came from a satellite.:roll: -
Re: World's Highest Solar Powered Webcamand here i thought the highest solar powered weather cam came from a satellite.:roll:
What's the URL for that ??Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Maybe it should be renamed terrestrial web cam. I have one at 640 ft, what might be the lowest elevation and highest elevation for a solar powered web cam in the world that is accessible by your web browser. -
Re: World's Highest Solar Powered WebcamWhat's the URL for that ??
you'll have to ask the national weather service that question or you can receive it in the 137mhz area with the proper equipment.:D -
Re: World's Highest Solar Powered Webcamyou'll have to ask the national weather service that question or you can receive it in the 137mhz area with the proper equipment.:D
But's that's not a web cam, it's the downlink from the sat.
i am quite sure it would be available on the web, but the fact that it is not hooked directly from the camera to the web does not disqualify it as the highest. this may seem to be nit picking, but even webcams are wireless sometimes and you don't necessarily need a solid wire connection to qualify. the wireless aspect is just a bit more distant.:roll::D -
for my purposes, I define a web cam, as something accesable with a URL, not an antenna and downlink
Like the Yeti cam, also up in the mountians. Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 234 Forum & Website
