You have to wonder
Where do people get their information from?
This was posted on the local Craigslist (BC Hydro will be implementing Smart Meters soon):
SMART METERS, THE DARK SIDE OF GOVERNMENT AGAIN!!
A smart meter will be transmitting and hydro will be logging and storing the data, they will have a complete history of your coming and going in your resisdence. They now know when you are likely to be home or not, eventually someone you DONT WANT to have this info will get a hold of it. Do any of think this might be an invasion of your privacy?
And here I thought they just logged how much power you use at what time and adjusted (upped) your bill accordingly. I didn't know they could magically watch you in your home. :roll:
Got paranoia? :p
    Re: You have to wonder
    We have had this debate in California for years...
    The first is that the meters broadcast the data via digital radio (many people seem to be very concerned about radio wave emissions).
    And the utility will log the information every hour (or every 15 minutes for commercial)--Allowing the utility to close monitor household energy usage (and, by assumption, know when you are home).
    So far, the bigger issues that have gotten traction are security of the transmissions/meters, inaccurate meters (sometimes overcharging), and billing issues (appeared to be some issues with meter reporting and/or corrupted data packet being placed in utility file and never corrected).
    And my favorite (which has not been reported anywhere that I have seen) is that smart meters can turn on/off the utility power remotely. I know an electrician that has reported dozens of meters that have turned off one leg of the 120/240 VAC split phase power to homes in our area (utility has to come out and replace meter). Hopefully the utility/meter company(ies) have fixed this problem.
    I certainly worry that the meter network could be hacked--There could be a lot of havoc created until the network is fixed/updated.
    You can see lots of interesting information with a Google Search.
    Trust me: burglars have easier ways of knowing when you're home or not. They aren't going to bother hacking a network and sifting through data on millions of homes to find out where and when to hit.
    That things will go wrong with the system is an absolute certainty. Things go wrong with the system we have now with exactly the same results as you mentioned.
    Plus ça change, plus c'est la même chose!
    Slashdot just had an article on them a while ago:
    Meters can spy on TV viewing:
    http://www.smartgridnews.com/artman/publish/Technologies_Metering/Smart-meters-can-spy-on-TV-viewing-habits-researchers-claim-4017.html
    The meters "relay" signals (like wi-fi signals - I think they use zig-bee ) from one to another, so while your meter only updates it's data evert 30 minutes or so, it's constantly acting as relay for everyone else too. So, there is a lot of EM "SMOG" which will effect your wifi connections. But you dinner in the microwave comes out faster !
    And the billing department can switch them off and on remotely.
  • ggunn
    mike90045 wrote: »
    They always could; it just took dispatching a truck and a technician to do it. There's no reason to suspect that the fact that they now can do it by data transmission will make it any more likely that they will cut you off.
    ggunn wrote: »
    With SmartMeters, the clerk at the billing desk, could switch it off at 12:01 AM, when your payment is late, and switch it back on at 9:02am when the bank transfer happens, along with the late fee. The old system to roll a truck to pull the meter, gave you an extra day or 3 of grace. And you can bet the disconnect / reconnect fees will be used a lot more than before.
  • GreenerPower
    GreenerPower Solar Expert Posts: 264 ✭✭✭✭✭✭
    There are states with regulation that the Poco can not cut power even though the customer didn't pay the bill for sometime. Before the smart meters, there are "smart meter socket" that the Poco can control remotely. They would cycle power on/off every 1/2 hour or so. People would go nuts and have to pay the bill.
    GP
  • DarkStar
    DarkStar Registered Users Posts: 12 ✭✭
    mike90045 wrote: »
    There is currently no Smart Meter on the market that has the capability of remotely switching off the power to a home. Seriously, there are no relays inside of these things and it is a direct copper connection from service to home.
    Here's a link to an ifixit teardown of a Elster REX2 Smart Meter being installed in a lot of areas: http://www.ifixit.com/Teardown/Elster-REX2-Smart-Meter-Teardown/5710/1
    DarkStar wrote: »
    Well, the original old ones used a Triac to switch power - relays are so old school
    http://www.wired.com/threatlevel/2010/03/smart-grids-done-smartly/
    "But even more pressing and immediate, in terms of vulnerabilities, is the remote shut-off capability in smart meters. Digital smart meters have an electronic disconnect switch that allows the utility company to shut down electricity remotely." ........ UPDATE: In a follow-up e-mail, Moreno said that “most of the 2.2 million second-generation electric SmartMeter meters are capable of remote connect/disconnect.”
    Because a company does not use the feature, does not mean it doesn't exist. 80% of the reason for smart meters, was to institute neighborhood blackouts in order to preserve the Grid. (That worked real well for the San Diego blackout 9-2011) http://en.wikipedia.org/wiki/2011_Southwest_blackout
    http://en.wikipedia.org/wiki/Smart_grid#Load_adjustment
  • jagec
    jagec Solar Expert Posts: 157 ✭✭
    Got paranoia? :p
    The idea is that the smart meter can tell when you're using power (more likely to be at home) and when you're not.
    Of course, a burglar could just look at the windows and see if you've got any lights on. This type of monitoring occurs in real-time, WITH a "smart sensor" that can tell the difference between power usage due to lights/TV vs. power usage due to fridge/sump pump/wireless router/AC. Sounds like the burglars already have better tools than the government!:D
    As for "they can turn off your power", well, they've always been able to do that...I'm only going to complain if they start turning off my power even though I've paid the bill.
    here's the sad news about the protective tin foil hats:
    http://berkeley.intel-research.net/arahimi/helmet/
  • solar_dave
    LMAO only at Berkeley!
    mike90045 wrote: »
    modern day dunce hats by any other name.:roll::p
    i'm not too sure that the guys doing the study shouldn't be wearing them as well. i guess their next project might be a study as to why many people who hit themselves in the head with hammers tend to be angry and in pain with or without previous said tin foil hats. geeez.:roll:
  • waynefromnscanada
    niel wrote: »
    Hahahaha I LOVE it! On a sadder note, there are those walking among us who would swear all this is true - - - and some of them want to run the country :cry:
  • techntrek
    Crap, now I need to upgrade my tin-foil hat.
    techntrek wrote: »
    ok, try it 1 inch thick and then you can do a study on why you neck hurts.:cry::p:p:p
  • solar_dave
    niel wrote: »
    Perhaps made out of Copper sheeting might to the trick! :D:D:D:D
    solar_dave wrote: »
    better yet make it an expensive one made of silver, gold, or platinum at 1in thick and let me try the prototype.:D:D:D:p
  • techntrek
    Nah, I just need to use a fine mesh and tie it to a ground rod. I figure I can make it portable by driving the rod into a gallon jug filled with dirt. tongue.gif
  • ggunn
    Beeeebeeeebeeeebeeee... POLITICS PROXIMITY ALERT! :D
  • bmet
    bmet Solar Expert Posts: 630 ✭✭
    Once spent a day at Garner State Park. Camcorder needed a charge, so I plugged it into an empty 'cabin'. Immediately a park ranger pulled up to the same cabin, went inside, found the device, and started looking around for the owner. I figured I should fess up or possibly have it claimed by the park. The ranger wasn't upset, but apparently they have some monitoring capability, whether it was a smart meter, surveilance camera, or co-incidental timing, I don't know.
    I was allowed to finish charging my camcorder.
    bmet wrote: »
    it makes me wonder why they needed to monitor it? are they now called power rangers?:confused::p:p:p
  • OK0KOK
    OK0KOK Registered Users Posts: 6
    You Guys crack me up!!!!!:D:D:D
    .:cool:
