anyone know much about these Korean Panels?
rollandelliott
Solar Expert Posts: 834 ✭✭
http://www.s-energy.co.kr/MalgumBoard/DownLoad.asp?sFileName=SM%2DXXXPC8+Series%5FSilver+2011%2Epdf&sFilePath=/upload_files/MalgumBoard/Download/2011/08
Re: anyone know much about these Korean Panels?
I have no experience with them, but when I read 24V nominal and see most of the panels have a VMP of 30 volts or less that sends up lots of red flags for me.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
why is that a red flag? -
You can view real-world performance of those panels on quite a few installations here:
http://www.solar-yield.eu/plant/search
Type in "s-energy" in the "Module Producer" field. -
Re: anyone know much about these Korean Panels?rollandelliott wrote: »why is that a red flag?
A 24v panel usually indicates that it should have 35ish VMp to be able to charge a 24v bank. You need just under 30v to do that. If the panels max is below that, there is an issue. That is my noob answer to your question. Others will have the exact answer shortly. -
Re: anyone know much about these Korean Panels?A 24v panel usually indicates that it should have 35ish VMp to be able to charge a 24v bank. You need just under 30v to do that. If the panels max is below that, there is an issue. That is my noob answer to your question. Others will have the exact answer shortly.
That is the right answer.
A Vmp of 30 is too high for a 12 Volt system and too low for 24. You would have to use an MPPT charge controller and for 24 Volts put two or more in series. Otherwise the inevitable Voltage losses from heat, wiring, and controller could leave you with too low a charge Voltage in the middle of the day when you're trying to get through the Absorb cycle. But that's in respect to an off-grid application.
Most likely these panels are meant for a grid-tie system. 12-16 in series would yield 360-480 Volts, which is what you might expect for central inverters. You'd have to check with manufacturers to see if they'd be compatible with microinverters. -
Just found out these panels are not UL rated.
So for many they can't be used on grid.
Their voltage is too low for a battery system.
So what are they good for?
Just direct drive applications like fans and pumps?
Seems too limiting. -
RE,
As Coot said in the post just above your most recent, "You would have to use an MPPT charge controller and for 24 Volts put two or more in series".
So, yes you can use them in a 12, 24, or 48 volt system if you use an MPPT controller with appropriate specs.
The MPPT controller Buck the input voltage of several of these panels in series to a lower battery voltage.
VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Im still trying to find more info on these panels... anyone else have any luck?
- 654 Solar Water Pumping
