Inverter / Charger ?
Jcrabtree
Registered Users Posts: 24 ✭✭✭
In debate on which to get - looking at two:
Magnum Energy MS-4024 Inverter/ Charger 4,000 watts 120vac
Outback FX 3524T inverter/charger 3,500 watts 120 vac
are there any major difference's between these two
edit: typo
edit: typo
Re: Inverter / Charger ?
For starters I would not run 3.5 to 4 kW from a 24 v battery.
You need to examine each spec and compare one to the other. Different items might be important to you.
Is this for off grid or grid tie backup. Generator input? -
off grid with genny as needed - 1-2kw system for starters -
Main differences:
Magnum has slightly higher output capacity. It also has a power factor corrected charger which will be "easier" on a small generator. Very easy to set up; basically connect the wires and turn it on.
Outback has connectivity to other OB equipment for seamless (albeit expensive) integration. Highly programmable which allows for more flexibility in system set-up, if somewhat daunting. Probably the "toughest" inverter on the market, even if it is "old tech".
I disagree with RC regarding the 24 Volt system & this size inverter. It is extremely unlikely you'll be running close to maximum capacity most of the time. Even so it would be under 200 Amps for those occasional peaks. -
thanks for the reply - Have been looking into the Pre-wire setups with midnite 150cc
- 230 Forum & Website
