Question on battery cables
How flexible are #2/0 cables? Can you bend them to a 4" radius?
Has anyone connected battery posts that are 4" apart using #2/0 cables?
Regards and thanks.
Regards and thanks.
Re: Question on battery cables
Gosh, me thinks it depends on what type of cable it is. I have some 2-0 ( maybe larger?, the copper is almost 1/2") and it is very flexible. It's made for welding cable and I'll bet it has 100 strands of copper. I just tried and can easily bend it into a 2" circle. But, if your cable has less strands it will not bend as easily. The only way to know for sure is buy one foot of your proposed cable & try it. -
No problem with welding cable. Finer strands, bends nicely. You can buy less expensive wire, with less strands, that hardly bends at all.
The largest welding cable I'm presently using is 4/0. Here's where I bought it:
http://wesbellwireandcable.com/Welding.html
Making up short cables is easy with a Lenco Anvil type crimper. Bought mine on Ebay years ago ($14)
Thanks for the reply and the link. I needed to know if I should get a bigger battery cabinet. Your answer tells me that I do not. -
Re: Question on battery cablesThanks for the reply and the link. I needed to know if I should get a bigger battery cabinet. Your answer tells me that I do not.
If your just upgrading in an existing cabinet, cool, but if this is a new cabinet, or first cabinet, it does not hurt to allow for expansion if space and money permit. -
I agree that a good quality welding cable is very capable of tight bends like you mentioned. I use 4/0 welding cable on all my battery connections and the flexibility is great.
I use the same crimping anvil as 2manytoyz and it works great. I just use it in a big vise, because it is easier to control the crimp that way.
Edward -
I'll be housing 8 Trojan 8D-AGM's in an old 19" Computer Rack.
Using welding cables will allow me to install the Inverter and related components in the same cabinet. This is my first ever Battery Backup system. It's main purpose will be to run my 230VAC well pump and the furnace at night. Eventually I plan to add solar panels. -
Be really careful with the wiring--Metal frames, sharp edges, etc. could really ruin your day if it cuts a battery cable (use proper clamping/insulation to protect the cabling).
Also, lead acid batteries, especially flooded cell lead acid batteries, will give up an acid mist while charging (as well as hydrogen gas). Make sure the box is properly vented and acid mist does not get into your electronics.
Sealed batteries (like AGM) do not out-gas/mist--except when they get old and fail (or are over charged/over heated and vent). So you still need to treat sealed batteries with respect too.
This stuff is great to work with. I don't see why it would not work. I don't know what the difference between marine/boat wire and welding wire is.
http://shop.genuinedealz.com/Marine%20Grade%20Wire/Marine%20Battery%20Cable/ -
I buy from Genuinedealz all the time, never a issue and FREE shipping. Boat Wire is tinned inside the insulation and has fine strands and very flexible, most is jacketed and has 2-3 conductors. The Battery cable that is shown in your link has less strands than regular boat wire and is not as flexible as welding cable because the jacket is PVC. 4/0 is pretty big, I'd use the welding cable. The " ABYC " code requires battery cables to be color coded and I'v never seen red welding cable.
Interconnecting batteries is always a trick to getting the wires positioned around so you can get the caps off easily to water them and keeping them clean, welding cable allows you to do that. -
Re: Question on battery cablesBlackcherry04 wrote: »The " ABYC " code requires battery cables to be color coded and I'v never seen red welding cable.
I recently bought 6ga, and 4/0 RED welding cable from here: http://wesbellwireandcable.com/Welding/Welding4_0.html
They carry red & black welding cable in 6, 4, 2, 1, 1/0, 2/0, 3/0 and 4/0.
I have no affiliation with anyone. Just pleased with their product. -
Thanks for the link. I guess I should have qualified it by saying , my local welding shop doesn't have red. I am sure if there was a market for it, they'd make in Pink.I recently bought 6ga, and 4/0 RED welding cable from here: http://wesbellwireandcable.com/Welding/Welding4_0.html
Actually, Our forum host has the red and black welding cable at a lower price then the posted link. :Dsolarvic:DBlackcherry04 wrote: »Thanks for the link. I guess I should have qualified it by saying , my local welding shop doesn't have red. I am sure if there was a market for it, they'd make in Pink. -
I have just done my first system with 2/0 cables that I got at our local swap meet. My red cable is very flexible with many strands while the black cable has only a dozen strands or so and is very stiff. However, I can bend the stiff cable to a shape and it will hold it. -
Just be sure the crimp terminals you use, will "stay" crimped with the fine strand cables, needs a lot tighter crimp to hold well, and keep the resistance down.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I took a $10.00 pair of Chinese bolt cutters and heated the blade cutting edges and drilled out a crimping die in a couple different sizes. They work like a $250 set. If interested you can go to the Greenlee site and find the size to drill them. -
BC04, have you got a short description of how you did the transformation, a pic too?
thanks
Eric
Buy set of these.
http://www.harborfreight.com/24-inch-bolt-cutters-41149.html
Heat up the cutting edges of the cutting blades ( to remove temper ) cherry red on just the edges.
Drill in the center with blades closed, you then create a die with half the hole on each blade. Size the hole to what size wire your crimping.
I don't have mine at home, they are at the lake so I can't post a picture today.
They'll look like this, except the won't cost $300.
http://www.reliable-equip.com/pg45re.html -
thanks, I thought that was how it had to be done.
I have an old pair of cutters I can use that look just like the HF ones...
Did you drill as close to the fulcrum point as possible to max out the leverage?
Eric
I'm just curious how this works, I use a quality set of bolt cutters and they only ope 3/8" max, I have some 000 lugs they must be 3/4" around, even with a hole drilled, I can't see how you can wedge one in. I can see maybe cutting a 'V' groove one one side and a open tooth like thing, so you could press a crimp like a hammer crimper.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Speaking of Harbor Freight,
Some here have recommended in the past using the HF Hydraulic Lug Crimper. I've not, but am considering buying this one just to try:
http://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html
Crimpers of all types are often very sensitive to the exact lug design that one is crimping.
Any crimp CAN work, but as a matter of safety it is important that crimps are reliable over time ... and so on. VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
