Can the Xantrex XW4548 put out both 120 and 240 volts at the same time?
tonygcan
tonygcan Solar Expert Posts: 91 ✭✭✭✭
Hi Guys,
Just wanted to thank this forum and its members for helping plan my solar setup which I ordered today from Northern Arizona W&S. I hope to get the equipment into the Philippines by the end of June.
My final list of components:
12 units Kyocera 185 watt panels
1 unit Xantrex 60 amp Mppt CC
1 unit Xantrex XW 4548, 120/240 sine wave inverter
1 unit Trimetric battery monitor.
Would anyone know if the xantrex inverter is capable of putting out both 120 and 240 volts at the same time?
    BB. Super Moderators, Administrators Posts: 33,744 admin
    Re: Can the Xantrex XW4548 put out both 120 and 240 volts at the same time?
    It is a 120/240 VAC split phase output inverter... Basically, exactly the same as a North American 120/240 VAC home service.
    Remember that it cannot output all 4.5 kW to a 120 VAC load--The loads have to be spread out on both L1 and L2 and the neutral--Or a pure L1-L2 240 VAC load (240 VAC well pump for example).
    I believe any of the current XW product can be reconfigured (and firmware change) to a pure 120 VAC inverter if you do not need/want 120/240 VAC output.
    And the 6048 is only a few $ more, for a lot more capacity. And yes, I run the 240V well pump, and 120V loads at the same time. Even runs the pump and the welder at the same time (while the sun is up)
    But I think I'm going to have to get the load balancing transformer to keep the house happy.
  • tonygcan
    Thanks Bill,
    I will want to have both 120 and 240 volts available. That's good to know.
    Thanks.
