What is the best racking for corrugated metal roof ??
Batikikik
Batikikik Solar Expert Posts: 141 ✭✭✭✭✭
thanks
    Re: What is the best racking for corrugated metal roof ??
    Batikikik wrote: »
    thanks
    Ground or pole mount. Most corrugated metal roof is very lightweight, and very thin frame work under it.
    If it's really beefy structure underneath, drill thru the peaks, and bolt to the members underneath the metal. then apply lots of sealant.
  • Jburgess
    Jburgess Solar Expert Posts: 130 ✭✭✭
    Mine is attached like this, if this is kind of roof you mean.
  • rollandelliott
    rollandelliott Solar Expert Posts: 834 ✭✭
    if you want to make your own easternmetalsupply.com has all kinds of aluminum bar/rod/extrusions.
  • Tumbleweeds
    Tumbleweeds Registered Users Posts: 6
    You might want to check with a PROFESSIONAL roofer before drilling/ mounting through the peaks, flexing from wind loads guarantees leaks, loose connections, failing mounts. I might be new at solar stuff, but I've got 50 years experience in metal roofs of all kinds.
  • Batikikik
    Attached some photos
  • Jburgess
    Here’s some photos to match the drawing I posted.
    Standoff without boot
    Standoff with boot
    Nut on underside.
    Hope this helps.
  • Batikikik
    Looks like you have to drill steel joist and attach with bolts under. Do you have more pictures which show layout . This prosolar`s racking cost 12c per watt right ? We have 3 deg slope and we have to raise to get 15 degree. I dont know if this is the but solution or not.
    Thank you
  • Jburgess
    Yes the holes were drilled to attach to the web of the purlins. Don’t really know the cost of the prosolar racking, My roof was at 18 degrees so the panels are flat with the roof.
    The panels made the building noticeably cooler in the summer from the shade.
    There is also a dozen pages of engineering calcs. as most steel buildings are minimally engineered. Fortunately mine had 12 inches more of snow load that required, so no additional bracing was required for the addition of the solar panels.
    Is this what you were looking for as a picture of layout?
  • System2
    System2 Posts: 6,290 admin
    Jburgess,
    Looks good. I'm planning on installing an array on my pole barn with the same type of metal roof, but I have rafters. What type of racking did you use with your Projacks? Thanks.
    Eric
  • Jburgess
    The racking is prosolar only because I was trying to match the exsisting racking when I expanded my system.
    Old panels are dirty, new are clean.
  • Batikikik
    I think there should be better options now ? Is there any another solution except prosolar? Because this project is 645kW And its gonna be 2800 drilled Holes which I dont like it :))))))))))))))
  • Batikikik
    And is it possible to give tilt to array ?
    Thank you
  • Peak Solar
    Peak Solar Registered Users Posts: 13
    http://www.s-5.com/clamps/index_2626.cfm
    Don't worry about the tilt on a job that size. The slight increase in energy production will not outway the increased racking costs associated with tilting the modules.
  • Batikikik
    Peak Solar
    I have a pitched roof , which has 4 Deg Slope (12/0.5). I have attached photo.
    Slopes facing north and south. I am looking for the best racking to have 12 degree facing south for both sides .
    thank you
  • Blackcherry04
    Not trying to Butt in, but can't you just use different length standoff's ?? I had a 12/5 pitch and used 3" on the front rail and 6" on the rear and the cost was less then $2.00 per standoff. I thought about them catching wind, but they are low enough below the ridge, it doesn't seem to be a problem.
  • Batikikik
    I dont know exactly. Even I dont know if it is a good idea to have a tilt on corrugated metal roof . I have never done large installation like this on corrugated metal. Project size is 625 kW .
    Thank you
    how would the roof know that 2 of the posts are 6 inches and 2 are 3 inches? it doesn't and there will be better cooling of the pvs with that 6 inches on 2 posts.
  • Solar Guppy
    How are you modeling / calculating the inter row spacing to prevent module shading due to the proposed angle lift?
    In a project this size, I would not add tilt, I would add modules as for the same sf, all being flat will bring in more harvest than spaced out with less panels on tilt
  • Jburgess
    Here's a random picture on the web of tilt racking on a metal building:
    Batikikik wrote: »
    thank you
    You better get an engineer on the project to consider windload, from the north. Those panels will grab the wind and carry the building away !!
  • Batikikik
    mike90045 . Engineering is done already. And it is not gonna take the roof out.
    Solar Guppy I agree with you to optimize rood and maximize solar output its better to have modules flush with roof than have inter row spacing.
    But this building`s roof has only 4 Deg slope. Inter row spacing will not be that much .And tilt angle will be 12 Deg facing south .
