plug hybrid truck?
xiphias
Solar Expert Posts: 52 ✭✭✭✭
Have been googling around to little avail. Interested in someday having a plug hybrid truck (or SUV) capable of towing 5000-10,000 pounds. Towing is intermittent, short-distance (<20 miles), and highly seasonal. Mostly vehicle will do short non-towing commute that can utilize electric. Annual overproduction of GT PV system should cover 4000-5000 mi/yr, which is about the total annual mileage.
Where should I be looking for this in U.S.? Manufacturers? After-market or guerrilla retrofit? If the latter, which vehicles are good candidates?
Thanks.
Thanks.
Re: plug hybrid truck?
There are several people offering plug in S-10 pickups kits. Range is like 50 miles, I suspect towing that would be reduced by half. Your 5ton load is pretty high. -
I'v gone to a couple of those S10 websites because I was interested in how they were charging their batteries. It looks like they haul around a 1000 lb of batteries and have big time longevity issues. Most place's will not honor their warranties for their batteries any longer. Homemade may not be the way to go. -
GM makes (or made) hybrid trucks: http://trucks.about.com/od/2007chevytrucks/a/09_silverado.htm
Not an endorsement or recommendation. Heck, I drive a 18-year-old gas-sucking monster 3/4 ton van so what do I know?
That towing capacity is pretty high, though. I'd want a one ton to move that much weight - even briefly. -
Thanks. Saw some S10 stuff and reached similar conclusion.
OK, cap the tow load at 7500. Plug hybrid. Other options? -
Re: plug hybrid truck?Thanks. Saw some S10 stuff and reached similar conclusion.
The plug-in hybrids have a very short battery only range. Towing will reduce that significantly.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 230 Forum & Website
