Need xantrex gti !!!
![fiddlehead](https://w4.vanillicon.com/4e4c5a4fbd2b217776c07b87347b76b7_100.png)
fiddlehead
Solar Expert Posts: 29 ✭
Looking for a Xantrex GTI for a customer. Anyone out there looking to sell one?
Re: Need xantrex gti !!!
found one works good -
Dang! I've got one still in the box!
Ralph -
Just landed another off-grider moving to the dark side. May need it, how much? -
GTI =Grid Tie Inverter ? What size ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
No Mike, it's a GT interface, between the inverter and the utility. SW inverters couldn't meet the UL1741 requirements without it (as I was informed by RCA in FLA).
I found that applying utility power to an SW4048 worked fine until you removed it. The inverter would not drop and invert right away..really messed up freq and voltage for many seconds. Workaround by fooling the SW into thinking that utility power is generator power...shut down ''generator'' and SW drops, goes to invert within 1 cycle. Just remember to shut the utility breaker off or the SW will see power...start charging...and so on.
I just interrupt the genset control wire with a switch in a utility box screwed to the inverter...labels UTILITY and GENERATOR at appropriate positions for switch. Works great. I've only forgotten to shut off the utility power breaker 2 or 3 times so far. The first time I thought we had lots of wind, the SW kept the batteries floating for 2 days
Ralph -
Thanks anyway Mike 90045. I need a Grid Tie Interface.
- 626 Discussion Forums/Café
