Home made PV system
mlodewyks
Registered Users Posts: 4 ✭
Hi all,
I'm quite new in the whole solar setup field, so be gentle.
I've been busy constructing panels, building a battery enclosure etc for the past couple of months, and I need some questions answered before I can continue with my green endeavors. First some background and eventual outcome (planned) info:
My intention is to end up with a system that can atleast supply power to the house during the day, and run lights and TV type appliances during load shedding hours.
I've bought a 6kVa 6000W Home UPS inverter (http://www.maidenelectronics.co.za/pINS6000/e-6000w--6kva-Home-UPS---Pure-Sine-Inverter.aspx), will have 16 105AH Deltec deep cycle batteries, and 16 60W home made PV panels on the roof. I used 3x6 Evergreen Solar cells to construct the panels, and the first 4 panels are all giving 19.5V and 3 - 3.5amps in full sun. On cloudy days like yesterday the measurements are 18V and 1amp. Here in Johannesburg we get an average of 8.7hours sunshine per day during a year, so for most of the time the panels should be running at "full" output. (I hope).
The first question I need answered is this: The current panels put out 3.5 amps (I intend to run 3 panels in series to charge a 4 battery bank), if I build panels using 6x6 cells which are rated to put out approx 8 amps in full sun, and I connect these panels into the array, what would the effect of the 3.5 amps and 8 amps panels be on each other? How does the amp output change if I use different amp rated panels together?
Thanks for helping,
Martin
Thanks for helping,
Martin
Re: Home made PV system
A few quick questions;
What is your battery bank voltage?
What type of charge controller will you be using?
Have you informed your insurance and morgage holder of your intention of mounting homemade panels on your roof?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Martin,
First, it is very difficult to build reliable/"fire safe" solar panels. Before you invest a bunch of time and money in DIY, try these few panels in the sun for a few months and see how they work. Personally, I don't believe they will last 1 year before they start to fail. And depending on how they are built and what fails--they can fail by catching stuff on fire.
Next, the 6kW inverter--Solar PV systems are very expensive to build and maintain--And most people over estimate how much power they can get generate and underestimate their loads. A 6kW is pretty large and would require a large battery bank and solar array to be useful for most people
Which gets back to the basics... I would recommend that you work on conservation first--It is almost always cheaper to conserve (new energy efficient refrigerator, florescent/LED lights, the most efficient A/C system you can use, and use fuel for cooking/heating/hot water.
Next, measure your loads--Peak Watts (starting surge), average Watts, and how many hours per day you run the load.
For example, a microwave running 1,500 watts for 30 minutes a day may actually use less energy on a solar power system than a 250 watt desktop computer system running 12 hours per day:- 1,500 watts * 1/2 hour = 750 Watt*Hours per day
- 250 watts * 12 hours = 3,000 Watt*Hours per day
Regarding your questions about solar panels... You have several choices to make...
First the charge controller. The less expensive charge controller is a PWM (Pulse Width Modulation) type. Basically an "on/off" switch between the solar panels and the battery bank. For best efficiency, the Vmp (voltage maximum power) of the solar panels should be just a bit above the battery charging voltage... Typically around 17.5-18 volts or so for charging a 12 volt battery (35-36 volts for a 24 volt bank, etc.).
A MPPT (Maximum Power Point Tracking) solar charge controller is much more expensive, but allows you to run Vmp of your solar array from ~17.5 volts to 100 volts Vmp for a 12 volt battery bank. The high voltage allows you to use much thinner copper wire from the solar array to the charge controller...
Remember that Power=Voltage*Current. 2x the voltage then 1/2 the current for the same amount of power. If your solar array is more than a few meters away from your charge controller (which should be close to the battery bank), a MPPT solar charge controller can make things much easier and keep the wire size smaller and less expensive.
When deciding on series / parallel arrangement for your solar array... Decide on your array's Vmp... If Vmp=17.5 volts and you have 17.5 volt panels, then you just put them in parallel. The output current Imp will simply add.
If you need Vmp=35 volts (24 volt battery bank and/or MPPT charge controller), then you would put two panels in series and put the rest of your panels 2 up in series, then parallel them together. Series, the Vmp will add, while the current remains the same.
If you have a mix of solar panels, Ideally the Vmp for parallel should all match to ~10% or better. For adding in series, the Imp of the panels should match to ~10% or better... The farther away you get from 10% match, the more power you will loose.
You have taken a pretty big bite of a complex issue... My recommendation--Don't buy anymore hardware until:- measure your loads
- look at conservation to reduce your power needs as much as possible
- plan your power needs in Watt*Hours per day by season
- plan the battery bank
- plan the solar array to recharge your battery bank
- plan the solar array to supply the power to support your loads (yes, you need to plan your array in two different ways)
- review loads and decide 12 volt / 24 volt or 48 volt battery bank
- Backup power (grid, generator). Size battery charger and power source to support battery bank in bad weather
- pick solar charge controller PWM/MPPT/Size/Options
- Now buy parts and install.
If you have hot water/heating needs, Solar Thermal panels (hot air, hot water) are actually a pretty nice DIY (do it yourself) type project... And much better place to invest your time and money for heating needs. Solar PV is just too expensive to run most heating loads.
I would read though this thread, defendantly look at post # 7.
http://forum.solar-electric.com/showthread.php?t=4524&highlight=panel+fire
As to your home made panels, put then on a shed or something like that.
Now, what is your current monthly electric usage?
We would like to help you go solar but not go broke and/or risk your safety. -
It would be interesting to hear what the $$$$ per watt is on the homemade panels. I saw solarfun panels on eBay yesterday for $1.89 a watt + shipping for Qty. 16. If you are in the LA area you can pick them up.
SolarFun, 195 Watt Polycrystalline Solar Panels
http://cgi.ebay.com/195W-solar-panels-24V-SolarFun195-1-89-per-watt-/180546398699?pt=LH_DefaultDomain_0&hash=item2a096769eb
or make a best offer. -
I looked at ebay listing. After clicking on condition,s It said part,s some parts are handmade. :DsolaRVIC:D:Dsolar_dave wrote: »It would be interesting to hear what the $$$$ per watt is on the homemade panels. I saw solarfun panels on eBay yesterday for $1.89 a watt + shipping for Qty. 16. If you are in the LA area you can pick them up.
this???
"New: A brand-new, unused, unopened, undamaged item (including handmade items). See the seller's listing for full details"
Standard eBay disclaimer for New Items. -
$1.89 is currently expensive for a pallet load of UL approved panels, the boat has arrived in Miami, currently at $1.48 for a pallet load of UL listed polycrystlin(msp) panels.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Home made PV system$1.89 is currently expensive for a pallet load of UL approved panels, the boat has arrived in Miami, currently at $1.48 for a pallet load of UL listed polycrystlin(msp) panels.
Just think, I paid about $ 4.00/watt three years ago.
- 232 Forum & Website
