Raised ground mount
arkieoscar
Solar Expert Posts: 101 ✭✭
Because of shade and roof type (old wood shake), I have to mount a 4000 watt array about 50 ft. from the house. Because of horses, I need to raise the whole thing up in the air. I'm thinking of building a pole structure and using a roof mount system on it. Anyone done this? I'm aware of the loads that it needs to handle and have that part figured out but I am worried that I'm missing something. I am planning on about 8 ft. clearance on the low side. They (the horses) should appreciate the shade. Any recommendations on a mounting system?
Re: Raised ground mount
I think this could work
http://www.dpwsolar.com/content/Support.aspx
Go there PowerFab Mounting Hardware>>Ground Mount Solutions>>>Large Ground Mount
It appears that you buy the Sch. 40 pipe locally and they supply the rest. -
Thanks Fatawan,
I'll check out prices on Monday. -
For those more experienced, in the pictures on the PDF from the page I linked, they appear to have 24 panels on mounts using only 6 concrete piers. Does that seem right? Are those normal sized panels(200-250W range)? If so, it seems like a great method to get lots of panels in a narrow space with the least amount of concrete work. -
Re: Raised ground mountarkieoscar wrote: »Thanks Fatawan,
I looked further at that site--you might want to look under "Multi-Pole Mounts" under ground mount solutions. That specifies "capable of significant ground clearance, and there are only vertical poles that the horses would have to deal with(horse doctor here--the less they can break their legs on, the better!). It sounds like they are adjustable angle as well. -
Here's some pictures of a few installs that might give you some ideas.
http://www.ratechsolar.com/index.php?left=mainleft&right=ground
Fences? It looks kinda like they have a chicken pen around that Los Gatos – 6.3 KW array.. -
Thanks Xringer. I'm calling some suppliers today. I've used the unirack before but there may be some good alternatives out there. I don't want to fence anything. More protection and output raising it and it can be mowed without worrying about flying rocks, etc. -
I used SuperStrut channel on my little 500w tracker mount..
http://www.grainger.com/Grainger/strut-channel/conduit-mounting/electrical/ecatalog/N-8aiZ1z0qlms
I used the smaller stuff. The next size up (at Lowes) was too heavy for me.
And, of course it flexed too much, so I had to use 4, instead of 2 big rails.. -
The super strut looks like it would work. I was thinking of spanning 8 ft. but maybe it would be best to frame it into 5 ft. sections so the channels would end on a joist. -
I needed 13 feet for my Ground Mount, so I used some 2x4s..
It was too heavy for me, so I used a little block-n-tackle to lift it up.. :cool:
800w on the platform and 500w on the tracker.
Someday, these things will be on the roofs.. :roll: -
The entire mount, or just the panels ??Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I'm waiting for prices on a couple of roof mount systems but it looks like it will be around $2K with shipping. When I get prices, I'll shop locally but added labor may make it just as expensive. At least the money for that will go in to the local economy. -
Re: Raised ground mountarkieoscar wrote: »I'm waiting for prices on a couple of roof mount systems but it looks like it will be around $2K with shipping. When I get prices, I'll shop locally but added labor may make it just as expensive. At least the money for that will go in to the local economy.
That price is for which one? For how large a system? -
I got a quote from our host that included Kyocera panels and a roof mounting system that will work for me. I'm going to use that quote in my proposal. The Kyoceras have a cross brace that will ease my worry about any warping in the framing.
- 230 Forum & Website
