New firmware available for Schneider/Xantrex, but not on website
Re: New firmware available for Schneider/Xantrex, but not on website
I can tell!Dave Sparks wrote: »This now a mature product so there should be little advantage to doing any firmware upgrade unless you have a reason. If it is not broke you still have the chance to break it. It is one of the reasons that X did not want to make firmware upgrades too easy to do! BTW, I agree with them if you can't tell! Good Luck!
So far it DOES appear to be a mature product, but since I am seeing discussion of problems connecting to a generator, I thought I would investigate so that I would be prepared if I faced it.
I do agree with you that updating firmware is a good way to create a boat anchor. While I have never had the fortune of having something "brick" on me, I have come close and have read many such horror stories on the internet.
Based on your advice, I think I will sit tight and see how things go with the generator start stuff. Thanks for reeling me in!
Your welcome. I bet you will be fine. I do not have grid-tie customers but all of my offgrid XW inv/chg's have not needed firmware updated. Only the CC needed firmware and that was years ago."we go where power lines don't" Sierra Nevada mountain area
Re: New firmware available for Schneider/Xantrex, but not on websiteRegGuheert wrote: »I can tell!
Xantrex firmware update is on schinder electrics page under downloads, if you use win 7 you need the additional drivers -
Re: New firmware available for Schneider/Xantrex, but not on websiteRegGuheert wrote: »No, I cannot. There is not enough information in this thread.
Let me reword the question to be more clear:
This system has the following information displayed:
XW6048 00
Model #865-1000
Serial #00001462CC93
Firmware Rev. 1.05.00 BN 11
Is the revision "865-1000.01_07_00.BN0003" a newer version of the firmware for this inverter or is it firmware for a different inverter (like for later serial numbers)?
i have all the updates for the XW6048 and drivers for win 7. if you have a Gen start you have to config that in the XW config. i just got back from the renewable energy show in tampa and i meet with schider. i have 4 XW6048 in my system and since i changed generators i had to reconfig the auto start
